Forum Topic - phinx for QNX 6.5:
phinx for QNX 6.5
I've started using QNX 6.5 as my development environment (was using 6.3.2 before).  When using 6.3.2, I used to export a
 display to a X Window Server on my host machine (QNX 6.5 is running as a VM) using phinx.
I can still use the phinx binary on QNX 6.5.0, but it is somewhat glitchy.  Is phinx still the way to view a photon
desktop using an X11 server?  Is there a QNX 6.5 version available?  Or source available, so that I can compile a
version against the latest X11 libraries (I suspect that the issues I'm seeing might be somewhat related to loading the
wrong library)?
James
Re: phinx for QNX 6.5
Hi, did you recompile the server Xphoton ?
The sources are available at http://sourceforge.net/projects/openqnx/files/
--Armin
 a display to a X Window Server on my host machine (QNX 6.5 is running as a VM) using phinx.
wrong library)?
> Thanks,
> James
> Photon microGUI
> http://community.qnx.com/sf/go/post67332
RE: phinx for QNX 6.5
Unfortunately phinx has been unsupported for quite some time.
From: James Fysh [mailto:community-noreply@qnx.com]
Sent: Wednesday, September 15, 2010 2:18 AM
To: photon-graphics
Subject: phinx for QNX 6.5
6.3.2 before).  When using 6.3.2, I used to export a display to a X
phinx.
glitchy.  Is phinx still the way to view a photon desktop using an X11
that I can compile a version against the latest X11 libraries (I suspect
wrong library)?
James
Photon microGUI
