How to lookup internal link using instance name at runtime?
08/31/2010 3:57 PM
post65311
I have an application that has multiple windows that are available for display. I would like for the user to be able to
select which window is opened from a list of available windows. My plan was to populate the list with the instance
name of each window. However, I could not find a function that would allow me to lookup an internal link using the
instance name string. Therefore, I could not map the user's selection to parameters needed by ApCreateModule().
I similar problem was solved by repeated calls to PtWidgetFamily(), getting the ApInstanceName() for each widget and
comparing that to the selection string. However, I do not know of a hierarchy I can traverse for widgets/modules that
have not been created. If there is one let me know, I am currently thinking of searching through the AbWidgets[] array.
