Re: RE: PhAB crashes on importing Photon 1.13 project/widget
07/06/2010 3:31 PM
post58774
No. For now, I recreated a a new bitmap using the pixmap editor. It appears that the new PtBitmap doesn't have an set/
arm property, which may be part of the problem?
Also the pixmap editor needs some work to make is a little friendlier :)
E.g. pressing Esc will promptly and without warning discard all your new carefully and lovingly created artwork.
Pressing "Apply" doesn't save the work in progress, which I found counter intuitive. (ie if you press apply and then Esc
, the changes "applied" are discarded too).
