Forum Topic - customize makefile:
customize makefile
Hi all,
I need to customize the PhAB makefile to copy the binary to a specific directory after compilation but i can't figure
how.
I could do this my self but i really want to automate the process.
Thanks in advance.
Gutemberg.
Re: customize makefile
You can use the POST_BUILD macro. Add it to the common.mk in the root of your project.
For example:
POST_BUILD=cp blah /tmp
or something like this:
define POST_BUILD
$(RM_HOST) $(HOME)/bin/$@
$(CP_HOST) $@ $(HOME)/bin
enddef
Once the target is built this command will be executed.
Here is the link to the docs: http://www.qnx.com/developers/docs/6.4.1/neutrino/prog/make_convent.html search for
POST_BUILD.
I'd tried this before but i was using the POST_BUILD macro at the begging of the common.mk file and it didn't work. And
the end of the file....worked!!!
thanks for the help!
