Forum Topic - glScissor and tiling memory on SGX:
Are full-screen and partial-screen glScissor calls handled differently?
I ran into an issue where a lot of partial-screen glScissor calls where being made and the end result was that a lot of
stuff ended up missing from the end rasterization.  Just setting the glScissor params to (0,0,800,478) instead of (0,0,
800,480) was enough to show this issue.
It kind of looks like some 64x64 macro-tiles are flat out getting dropped on the final render.  Is it possible that the
partial-screen glScissor calls are handled differently than full-screen ones, and are causing the SGX to run out of
internal memory for its tiling lists in this case?
Have you seen cases where tiles/macro-tiles have been dropped altogether?
RE: glScissor and tiling memory on SGX
You are talking about screen graphics stack I assume, just to be clear?
From: Chris Keating [mailto:community-noreply@qnx.com]
Sent: May 14, 2012 9:41 AM
To: opengles-graphics
Subject: glScissor and tiling memory on SGX
OpenGL ES
http://community.qnx.com/sf/go/post93044
To cancel your subscription to this discussion, please e-mail opengles-graphics-unsubscribe@community.qnx.com
Re: glScissor and tiling memory on SGX
Some of our older SGX drivers had issues with non-fullscreen glScissor
rects. However, glScissor performs badly on the SGX, and we recommend
using the stencil buffer to clip content.
-Joel
of stuff ended up missing from the end rasterization.  Just setting the glScissor params to (0,0,800,478) instead of (0,
0,800,480) was enough to show this issue.
the partial-screen glScissor calls are handled differently than full-screen ones, and are causing the SGX to run out of
> OpenGL ES
Deric:  Not screen per se.  Just GL stack in general.
Thanks Joel.  I'll have to play with that some more.  I initially was using
the stencil buffer but actually noticed a performance decrease at the time
and so I went back to using the scissor.
Chris Keating
Crank Software Inc.
Office: 613-595-1999 x515, Cell: 613-314-6136
Online: www.cranksoftware.com
Check out: Crank Software's Blog
There is a better way to build user interfaces for embedded devices.
Download a 30 day evaluation of Crank Storyboard Suite today!
From: Joel Pilon [mailto:community-noreply@qnx.com]
Sent: May-14-12 10:10 AM
To: opengles-graphics@community.qnx.com
Cc: Chris Keating; Chris Keating
Subject: Re: glScissor and tiling memory on SGX
rects. However, glScissor performs badly on the SGX, and we recommend using
-Joel
being made and the end result was that a lot of stuff ended up missing from
instead of (0,0,800,480) was enough to show this issue.
on the final render.  Is it possible that the partial-screen glScissor calls
run out of internal memory for its tiling lists in this case?
> OpenGL ES
OpenGL ES
http://community.qnx.com/sf/go/post93049
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2171 / Virus Database: 2425/4998 - Release Date: 05/14/12
Keep in mind, you should try to cache as many rects/masks in the 8 bit
stencil buffer. Multiple rects can be stored on each plane of the
stencil. Rendering the rects/mask is more expensive then the actual
stencil test. The stencil test is extremely cheap on PVR compared to
other architectures.
-Joel
> Chris Keating
> Crank Software Inc.
> -Joel
>> OpenGL ES
> OpenGL ES
> OpenGL ES
> http://community.qnx.com/sf/go/post93056
