Forum Topic - imx53 Quickstart GLES failure:
I have an imx53 quickstart board and am trying to run OpenGL ES 2.0 on it.  However eglGetDisplay fails for all apps
including the gles2-egl-gears app that I downloaded from the QNX website.  I am running with the imx gpu mgr patch and
have GRAPHICS_ROOT set and am running io-gpumgr.  I tried to pass NULL and a gf_dev_t handle into eglGetDisplay but both
 failed.  Has anyone gotten this board to work with OpenGL ES 2.0?
Here is my sloginfo after running an app incase that helps:
Jan 01 03:22:01    5 10721     0 gpu_i.MX51:  starting up...
Jan 01 03:22:02    5 10721     0 gpu_i.MX51:  running
Jan 01 03:22:14    6     8     0 get_config_data(): xres=800 yres=480 refresh=60 output_fmt=24 di_sel=0 board=1
display_type=0 yuv_layer=1
Jan 01 03:22:14    6     8     0 HDMI: SiI9022A Tx
Brian
Re: imx53 Quickstart GLES failure
I get run gles2-egl-gears (OpenGL) in inx53QSB and I get 196 FPS. I have heared that it could be run at 300FPS, but i
have the same problem as you when i try run egl-**** "Unresolved Symbol eglGetDisplay" Doy you get solve the problem?
If you want i tell you as i have done to run gles2-egl-gears
Best Regards,
