Forum Topic - How to display OpengGL Demos with VMware:
Environment:
    VMWare Player 3.1 + QNX 6.4.1
I copy the demo files ("egl-pdemo"/"gfi-demo") to QNX OS and run it. I got the failure "gfi_group_attach() failed"
Could you please tell me what's wrong with it.
Comments:
1. I have add the VMware device to display.conf
2. I run it under without photon.
Chen Shunli
AVNC&IS Division
Neusoft Co., Ltd.
No.2 Xin Xiu Street. Hun Nan New District,
Shenyang 110179, PRC
Tel:+86 24 83664044
Fax:+86 24 23781242
Email:chensl@neusoft.com
Http://www.neusoft.com
Confidentiality Notice: The information contained in this e-mail and any accompanying attachment(s)
is intended only for the use of the intended recipient and may be confidential and/or privileged of
Neusoft Corporation, its subsidiaries and/or its affiliates. If any reader of this communication is
not the intended recipient, unauthorized use, forwarding, printing,  storing, disclosure or copying
is strictly prohibited, and may be unlawful.If you have received this communication in error,please
immediately notify the sender by return e-mail, and delete the original message and all copies from
your system. Thank you.
RE: How to display OpengGL Demos with VMware
The gfi-demo is not an opengles demo and you'll need a touch screen or mouse.
Regardless, if you'd like to run it, you can try ensuring io-hid and devi-hid is running.
If not you can try:
io-hid -dusb
devi-hid -rP mouse
If your more interested in gles, you can try running egl-gears.
Note however, these are all legacy applications. Our new graphics uses composition manager (io-winmgr) to run graphical
applications in a composited windowing system environment. Some of these applications can be found in the public svn
repository under trunk/apps/kd and trunk/apps/egl.
It's probably also worth mentioning we support accelerated gles2 and vg on various platforms. Currently, we only support
 software gles1.0 under vmware.
-Joel
From: Chen ShunLi [mailto:community-noreply@qnx.com]
Sent: Tue 6/8/2010 10:29 PM
To: opengles-graphics
Subject: How to display OpengGL Demos with VMware
Environment:
Comments:
Chen Shunli
AVNC&IS Division
Neusoft Co., Ltd.
Tel:+86 24 83664044
Fax:+86 24 23781242
OpenGL ES
http://community.qnx.com/sf/go/post56350
Re: How to display OpengGL Demos with VMware
Thanks for your quickly response.
Our aim is Navigation with hardware, but we need a PC Simulator also. So I
think we can run it at VMware.
I try to run egl-gears just now but there is problem:
    I run it without photon( Because the function eglChooseConfig return 0
config with photon running ).
    After the egl-gears ran, the window is change to black but nothing
displayed in it.
Please check the attached 2 SnapShots.
Attachment: Image After Gear.JPG 38.07 KB Image Before Gear.JPG 30.32 KB
More Informations:
1. The OpenGL ES version is 1.4
2. Please check the attached display.conf
Attachment: Text display.conf 1.36 KB
