Forum Topic - Configuring Qt 4.6 opensource for qnx SDP-6.4.1-200905201802-nto:
I am trying to do benchmarks for different OS-es with Qt 4.6 opensource from Nokia. I have installed a virtual machine
with SDP-6.4.1-200905201802-nto, and tried to configure Qt for Qnx. I added the EGL and GLES library and include paths
under the supplied mkspec for Qnx, than configured with the following command.
 ./configure \
 -platform unsupported/qnx-g++  -no-libtiff  -no-qt3support  -no-gfx-linuxfb \
 -no-mouse-linuxtp  -no-kbd-tty  -qt-gfx-qnx  -qt-mouse-qnx -qt-kbd-qnx\
 -opensource  -opengl es1  -qt-libjpeg  -qt-libpng  -qt-libmng  -qt-gif  -silent
Configure runs Ok, and than I try to :
make install
which runs ok until trying to build OpenGL libraries. Here I got an error, whith
conflicting type declarations within EGL/eglplatform.h and GLES/egltypes.h
Honestly, I am confused, which declarations are meant for my use. Maybe I should just try to forbid use of EGL libraries
? there is an egl.h also within the GLES folder. (guess needed for the context creation).
Have anyone succesfully managed to build Qt opensource on Qnx SDP 6.4.1?
All help is apreciated,
Istvan
Re: Configuring Qt 4.6 opensource for qnx SDP-6.4.1-200905201802-nto
Ok, there are no responses, but I wrote down my experience, maybe it will be useful.
I added an additional define in the mkspec , with -DQT_GLES_EGL, so Qt won't use EGL and GLES simultanously. However,
the EGL and GLES egl differences are still not completely clear to me (but this is not qnx-related).
Also, there might be a bug in Qt according to http://lists.trolltech.com/pipermail/qt-embedded-interest/2009-December/
000767.html.
I edited Qt's qpaintengineex_opengl2_p.h file to get rid of the shader model (which i guess  not relevant for OpenGLL ES
 1.1. Now the build script is still running, so no more experience, but GL libraries at least are built with Qt.
If someone have some good results with Qt on QNX I will elcome this; if not, I hope this post will help others who
trying to build Qt on QNX.
RE: Configuring Qt 4.6 opensource for qnx SDP-6.4.1-200905201802-nto
Hello Istvan
Pretty sure you have seen this but have you tried to use the config line
verbatim from this page:
http://doc.trolltech.com/4.6-snapshot/platform-notes-qnx.html
There appear to be minor differences compared to yours (presence of
-embedded option; lack of -opengl option).
Have not built this myself so I'm just suggesting the obvious..
  Mate
From: Istvan Balazs [mailto:community-noreply@qnx.com]
Sent: January 11, 2010 9:29 PM
To: opengles-graphics
Subject: Configuring Qt 4.6 opensource for qnx
from Nokia. I have installed a virtual machine with
the EGL and GLES library and include paths under the supplied mkspec for
 ./configure \
-no-gfx-linuxfb \  -no-mouse-linuxtp  -no-kbd-tty  -qt-gfx-qnx
-qt-mouse-qnx -qt-kbd-qnx\  -opensource  -opengl es1  -qt-libjpeg
make install
error, whith conflicting type declarations within EGL/eglplatform.h and
GLES/egltypes.h
I should just try to forbid use of EGL libraries? there is an egl.h also
Istvan
OpenGL ES
http://community.qnx.com/sf/go/post44870
Re: RE: Configuring Qt 4.6 opensource for qnx SDP-6.4.1-200905201802-nto
Thanks for your reply,
I have sen the platform notes, but since I am building as a QNX-fan , I was interested whether I can use OpenGL or not.
If I fail to build it with OpenGL, I will try out the -embedded i386 option also, and check how it performs.
BR
6.4.1 comes with two OpenGL ES stacks:
1) A libGLES_C[M|L].so that contains EGL functions. With this library, there is no need to link with an EGL library. The
 <GLES/egl.h> header is the one that should be included in this case.
2) A libGLESv1_C[M|L].so that doesn't contain any EGL functions. With this library, a separate libEGL.so, which contains
 the EGL functions, must be used. The <EGL/egl.h> header is the one that matches with libEGL.so.
If you are passing a gf_device_t to eglGetDisplay() somewhere, you must the EGL 1.2 functions contained in libGLES_C[M|
L].so.
Wow, thanks, that's exactly I wanted to learn.
Unwillingly I got the same the same result by adding -DQT_GLES_EGL, which does your case 1 :)
 QGL libraries built well with that, but guess there is no need than for the libGLESv1_C(M)(L) libs.
Thank you again. If anyone else is interested in the topic, I will attach the mods I made during the build if I finally
succeed with it.
I am interested in your modification to build Qt. How are the programs running?
Christian
I am interested also.
Thomas
My way to build QT for QNX on Linux Host
- Install QNX SDP 6.4.1 (Linux Host)
- Install QNX 6.4.1 (on VBox)
- Qt 4.6.3 source
- In mkspecs/.../  qnx-i386-g++.conf replace compiler version -> 4.3.3
- Build Qt-Embedded on Linux Host ::
./configure -xplatform unsupported/qws/qnx-i386-g++ -embedded i386 -no-gfx-linuxfb -no-mouse-linuxtp -no-kbd-tty -no-
qt3support -qt-gfx-qnx -qt-mouse-qnx -qt-kbd-qnx -no-exceptions -nomake demos -nomake examples
gmake
su -c "gmake install"
- Build Qt application with Qt Creator (set qt for QNX version)
On Target QNX system:
1) Copy Qt shared libraries [in 1 of LD_LIBRARY_PATH folders]
2) Copy fonts from Qt-Embedded
3) QWS_DISPLAY, QWS_MOUSE_PROTO and QWS_KEYBOARD
environment variables should all be set to qnx (edit $HOME/.profile)
4) Create sh-file::
	/usr/photon/bin/devi-hid -Pr kbd mouse
	./appname
	slay devi-hid
	sleep 1
	/usr/photon/bin/devi-hid kbd mouse
5) Exit Photon
6) Run It!
