Forum Topic - Bulid error : OpenKode,OpenVG:
Hi,everybody
  I am writing an application with OpenKode and OpenVG.And my enviorment is :QNX6.4.0 + Aviage HMI Suite 2.0
  I list my lib in "C:\QNX640\target\qnx6\x86\usr\lib" and get the result
2009/03/26  03:12                 0       libEGL.so
2009/03/26  03:12            62,126    libEGL.so.1
2009/03/26  03:12                 0       libgf.so
2009/03/26  03:12            92,505    libgf.so.1
2009/03/26  03:12           151,633   libGLESv1_CM.so.1
2009/03/26  03:12                 0       libGLES_CM.so
2009/03/26  03:12           166,032   libGLES_CM.so.1
2009/03/26  03:12                 0       libKD.so
2009/03/26  03:12            29,789    libKD.so.1
2009/03/26  03:12                 0       libWFD.so
2009/03/26  03:12            39,649    libWFD.so.1
2009/06/05  17:21           383,262   libOpenVG-G12.so.1
2009/06/05  17:21            27,036    libOpenVG.so.1
2009/06/05  17:21            38,742    libutil.a
The strage thing is that size of libEGL.so, libgf.so, libgf.so,libKD.so,libWFD.so is zero.
I fill the other option of linker option with
"-lgf -lEGL -lasound -lkd -lOpenVG  -lOpenVG-G12".
But when bulid, I got many errores.I think it will be the problem of link option.How can I do for it?
Thanks very much.
Severity and Description	Path	Resource	Location	Creation Time	Id
'image' undeclared (first use in this function)	my_application	my_event_process.c	line 311	1244465516977	3152
'image' undeclared (first use in this function)	my_application	my_event_process.c	line 411	1244465516993	3160
'VGImage' undeclared (first use in this function)	my_application	my_event_process.c	line 308	1244465516977	3150
'VGImage' undeclared (first use in this function)	my_application	my_event_process.c	line 373	1244465516977	3158
C:/QNX640/target/qnx6/usr/include/errno.h expected ';' before 'extern'		my_application	line 40	1244465516977	3149
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ';' before 'asm'		my_application	line 749	1244465516977	3139
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ';' before 'typedef'		my_application	line 59	1244465516946	3072
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 649	1244465516977	3122
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 661	1244465516977	3125
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 700	1244465516977	3133
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 702	1244465516977	3134
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 709	1244465516977	3135
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 718	1244465516977	3136
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 722	1244465516977	3137
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line 729	1244465516977	3138
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dstPath'		my_application	line 593	1244465516946	3098
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dstPath'		my_application	line 594	1244465516946	3099
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dstPath'		my_application	line 598	1244465516946	3100
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dstPath'		my_application	line 601	1244465516946	3101
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dstPath'		my_application	line 602	1244465516946	3102
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected...
RE: Bulid error : OpenKode,OpenVG
Hi Liu,
	Normally, your files with size zero should be links to the versioned .so files (e.g. libEGL.so linked to libEGL.so.1).
 Since you are running your build environment under Windows, just make a straight copy of the .so.1 files to .so,
replacing the zero length files (and don't remove the .so.1).  Furthermore, you'll need to also do this for libOpenVG.so
.1 (i.e. copy libOpenVG.so.1 to libOpenVG.so).
	As a second comment, when using OpenVG, your application should link against libOpenVG, and not against libOpenVG-G12
(this one would be used by the driver itself).
	As for the problems your getting when compiling, please try the attached header files for OpenVG.  I believe the files
you have are for a 6.4.1 environment.  So basically, you should simply put the attached files in your c:/QNX640/target/
qnx6/usr/include/VG/ directory on your build machine.  Please let me know how that goes.
Gaétan
From: liu liming [mailto:community-noreply@qnx.com]
Sent: June 8, 2009 9:14 AM
To: cwm-graphics
Subject: Bulid error : OpenKode,OpenVG
Hi,everybody
I fill the other option of linker option with "-lgf -lEGL -lasound -lkd -lOpenVG  -lOpenVG-G12".
Thanks very much.
C:/QNX640/target/qnx6/usr/include/VG/openvg.h expected ')' before 'dst'		my_application	line...
Attachment: Text openvg.h 34.03 KB Text vgplatform.h 2.98 KB Text vgu.h 5.57 KB
Re: RE: Bulid error : OpenKode,OpenVG
Hi Gaétan,
  Thanks your answer and I followed your advice.
1.I changed the filename
libEGL.so.1 		->libEGL.so
libgf.so.1 		->libgf.so
libGLESv1_CM.so.1	->libGLESv1_CM.so
libGLES_CM.so.1 	->libGLES_CM.so
libKD.so.1 		-> libKD.so
libWFD.so.1 	->libWFD.so
libOpenVG.so.1	->libOpenVG.so
libOpenVG-G12.so.1	-> libOpenVG-G12.so
2.I checked my include file of
"C:\QNX640\target\qnx6\usr\include\VG", and get the result.I think it will be ok.
2009/06/05  17:18	34,982 	openvg.h
2009/06/05  17:18 	9,892 	ovg11_api_backend.h
2009/06/05  17:18 	2,481 	ovg_backend.h
2009/06/05  17:18 	1,658 	ovg_driver_backend.h
2009/06/05  17:50	10,083 	vgext.h
2009/06/05  17:18	3,188 	vgplatform.h
2009/06/05  17:18	5,812 	vgu.h
3.And I set the other option of linker tab to:
But the error message is same.
Then I change the other option of linker tab to:
"-lgf -lEGL -lasound -lkd -lOpenVG"
and got the same error message.
Best Regards
Liu Liming
RE: RE: Bulid error : OpenKode,OpenVG
Hi Liu,
	Here are a few more comments / clarifications:
	1- 	a) libOpenVG-G12.so.1 doesn't need a .so link (but libOpenVG.so.1 does)
		b) You should also keep the .so.1 files around, so in the end you should have two copies of the same files, one .so.1
and one .so
	2-	a) Have you tried using the header files I had attached to my previous post?  The problem with the files you had was
 at the end of the files, where there's a call to __SRCVERSION (and in some files an #include of <sys/srcversion.h>, and
 6.4 doesn't have these defined.  It is safe to remove these lines.
		b) I suppose you have taken vgext.h from Khronos (as we don't provide this file...)?  Our OpenVG implementation
doesn't support the KHR extensions, so you should not be including this file from your application.
	3-	VGImage is defined in openvg.h, so if your application includes openvg.h (as it appears to be doing) and it still
causes compilation problems even with the __SRCVERSION references removed (as in the files I had previously attached),
then chances are there's a problem in your code before the #include statement.  The openvg.h file comes directly from
Khronos.  If after steps one and two above you are still having compilation problems, please attach the new build output
 (as it will be different than what you had previously attached).
Gaétan
Sent: June 8, 2009 9:57 PM
To: cwm-graphics
Subject: Re: RE: Bulid error : OpenKode,OpenVG
Hi Gaétan,
Best Regards
Liu Liming
CWM/OpenKODE
http://community.qnx.com/sf/go/post31173
Re: RE: RE: Bulid error : OpenKode,OpenVG
Hi,Gaétan
   Thanks for your answer and I had finished this question.
   1.When I use your header file in qnx6.4.0, complied failed beacause there is no sys/srcversion.h in qnx6.4.0
   2.So I update my os to Qnx6.4.1, then everything becames ok.
   Thanks very much for your answer.And best regard.
Liu Liming
> Hi Liu,
> have two copies of the same files, one .so.1 and one .so
> post?  The problem with the files you had was at the end of the files, where
> there's a call to __SRCVERSION (and in some files an #include of <sys/srcversion.h>, and 6.4
> file...)?  Our OpenVG implementation doesn't support the KHR extensions, so
> as it appears to be doing) and it still causes compilation problems even with
> ), then chances are there's a problem in your code before the #include
> statement.  The openvg.h file comes directly from Khronos.  If after steps one
> new build output (as it will be different than what you had previously
> attached).
> Regards,
> Gaétan
> To: cwm-graphics
> Hi Gaétan,
> ok.
> Best Regards
> Liu Liming
> CWM/OpenKODE
Regarding the compile error, check for a line like
__SRCVERSION( "$URL: http://svn.ott.qnx.com/product/trunk/...
at the end of include .h files.  If it is there, comment it and rebuild.
