Forum Topic - sysres utility:
sysres utility
The "Configuring io-winmgr" documentation:
http://www.qnx.com/developers/docs/6.4.1/composition_manager/dev_guide/configuring.html refers to "sysres utility" in
the explanation of the display/plane/egl-config parameter.
Is there actually a sysres utility or "sysres utility" refers to the -sysres option "io-winmgr -sysres"?
Re: sysres utility
The documentation refers to the sysres command line option of io-winmgr. Running io-winmgr -sysres--which should be run
before starting the io-winmgr resource manager--will give a complete list of EGL configs, display controller devices,
ports, and pipelines found on a particular system.
Re: sysres utility
Hi
if i run io-winmgr -sysres i am getting memory fault error! why?
Please help.
