Forum Topic - failed to kdCreateWindow:
Hi,everybody
   I install Aviage HMI Suite 2.0 and Composition Manager [Patch ID 1347] on Qnx6.4.0, and write a openkode application.
   But, the function of kdCreateWindow can't work and the error message is "kdCreateWindow not support".
   1.The init of EGL is ok
   2.My Display Card is : Intel G33,  and I select the dirver i830.
  For this thing , I install the QnxDsp6.4.1 and Aviage HMI Suite 2.0 and failued too.
  What can I do for it?
Thanks every much.
Re: failed to kdCreateWindow
kdCreateWindow raises the KD_ENOSYS error if the display argument does not correspond to a composited window system
display connection, and the KD_ENOMEM error if it failed to allocate a KDWindow * for the new window.
eglGetDisplay(EGL_DEFAULT_DISPLAY) will try to establish a composition manager display connection, and will fallback to
the null-windowing system connection with io-winmgr is not running.
I suspect you are getting this error because io-winmgr is not running.
Thanks every much.
I start io-winmgr , and log to the qnx by telent to start my programe.It works.
