Forum Topic - kdRealizeWindow:
kdRealizeWindow
Hi everyone,
I try to run an OpenKode application on top of a beagle board xM by using the foundry 27  Beagleboard-xM Support Package
. Unfortunately kdRealizeWindow always returns an ENOMEM-error. Hence it seems that it doesn't have enough memory
Has anyone succeeded in running OpenKode applications on the Beagleboard-xM and might give me some hints, which
configuration I need?
Thanks in advance,
  Bjoern
RE: kdRealizeWindow
I haven't worked on the Beagleboard, but I'll offer a shot in the dark.
The memory in question isn't just any memory, but it will most likely be
requesting a physically contiguous block from what is available at the
time.  If you are relatively low on memory, or if physical memory is
fragmented you will get this error.
Eric
Re: RE: kdRealizeWindow
That is what I assume too, but perhaps there might be some settings/ideas to increase the available memory. I hope
someone already tried openKode on the beagleboard-xM.
