Forum Topic - question about io-winmgr:
Hi, All
From the tutorials, it seems that io-winmgr is just a server.
I start io-winmgr with default config file, just get a black screen.
If my understanding is right, to make composition work, there must be a client app just like photon to provide a window
system.
Is there a window manager on qnx provide a environment like composite desktop, on which we can do rotate and reflect?
Thanks!
Re: question about io-winmgr
Yes, that is right, you can also specify a different colour if you so wish through the graphics.conf file.
>  app just like photon to provide a window system.
Yes there must be a client app that is running. But not Photon. You need to create client app(s) to run that use the
OpenKODE spec. Composition Manager implements part of that spec to allow for the creation, deletion, and managment of
windows.
These features are not implemented in CompManager at this point.
We also provide a delegate interface which helps to write a window manager.
The following tutorial is a simple example of a window manager:
http://community.qnx.com/integration/viewvc/viewvc.cgi/trunk/apps/kd/tutorials/gles1-kd-hmi/?root=graphics&system=
exsy1001
