background and foreground windows problem
07/28/2009 9:20 PM
post34763
in lcd driver, the foreground is enabled, and the color is set on the foreground in application test code, while layer
update, the layer program funcition in driver is call , the layer index is 0, SDC_BG_POS(background window position)
register is set, but not SDC_FG_POS(foreground window position) is set,right colors display, why? thanks
RE: background and foreground windows problem
07/29/2009 8:19 AM
post34779
Can you post your application test code? I assume from your
description below you are trying to display something to the foreground
layer (layer_index 1)?
From: gong mingyu [mailto:community-noreply@qnx.com]
Sent: July 28, 2009 9:21 PM
To: advanced-graphics
Subject: background and foreground windows problem
foreground in application test code, while layer update, the layer
SDC_BG_POS(background window position) register is set, but not
why? thanks
Advanced Graphics
http://community.qnx.com/sf/go/post34763
Re: RE: background and foreground windows problem
07/29/2009 9:21 PM
post34862
the lcd test code as follow:
int main() {
//device & display
gf_dev_t gdev;
gf_dev_info_t gdev_info;
gf_display_t display;
gf_display_info_t display_info;
int i;
//layer
gf_layer_t layer;
//surface
gf_surface_t surface;
gf_surface_info_t surface_info;
unsigned height;
unsigned width;
gf_layer_info_t layer_info;
//context
gf_context_t context;
if (gf_dev_attach(&gdev, GF_DEVICE_INDEX(0), &gdev_info) != GF_ERR_OK) {
printf("gf_dev_attach() failed\n");
perror( "gf_dev_attach()" );
return (-1);
printf("gdev_info.ndisplays: %d\n",gdev_info.ndisplays);
for (i = 0; i < gdev_info.ndisplays; i++) {
printf("Display %d: ", i);
if (gf_display_attach(&display, gdev, i, &display_info) == GF_ERR_OK) {
printf("%dX%d, refresh = %dHz\n", display_info.xres,
display_info.yres, display_info.refresh);
printf("display_info.nlayers: %d\n", display_info.nlayers);
} else {
printf("gf_display_attach() failed\n");
perror( "gf_display_attach()" );
gf_dev_detach(gdev);
if (display != NULL) {
if (gf_layer_attach(&layer,display,display_info.main_layer_index, 0) == GF_ERR_OK) {
printf("Attaching Layer %d to display.\n ",display_info.main_layer_index);
else {
printf("gf_layer_attach() failed\n");
gf_dev_detach( gdev );
return (-1);
if((gf_layer_query(layer,0,&layer_info))==GF_ERR_OK){
printf("Layer's Format 0 : 0x%x, GF_FORMAT_PACK_RGB565: 0x%x\n",layer_info.format,GF_FORMAT_PACK_RGB565);
else{
printf(" gf_layer_query() failed");
return (-1);
width = display_info.xres;
height = display_info.yres;
if (gf_surface_create_layer(&surface, &layer, 1, 0,
width, height, layer_info.format, NULL, 0) == GF_ERR_OK) {
printf("Succesfully created surface on top of layer\n");
gf_layer_set_surfaces(layer, &surface, 1);
gf_surface_get_info(surface, &surface_info);
printf("surface's Format: 0x%x, GF_FORMAT_PKLE_RGB565: 0x%x\n",surface_info.format,GF_FORMAT_PKLE_RGB565);
} else {
printf("gf_surface_create_layer() failed\n");
return (-1);
if (gf_context_create(&context) != GF_ERR_OK) {
fprintf(stderr, "gf_context_create failed\n");
return -1;
else{
printf(" Created the context succefully\n");
if (gf_context_set_surface(context,surface)!= GF_ERR_OK) {
fprintf(stderr, "gf_context_set_surface failed\n");
return -1;
else{
printf("Context Surface is Set Succesfully\n");
int x,y;
gf_draw_begin(context);
gf_context_set_penwidth(context, 1 );
gf_context_set_bgcolor( context, 0x000000 );//white, background is not enable
gf_draw_rect( context, 0, 0, width-1, height-1 );
gf_draw_flush(context );
x=400;
y=240;
gf_context_set_fgcolor( context, 0xFF0000);//red output mode 18 rgb565
gf_draw_rect(context,(width>>1)-1-x,(height>>1)-1-y,(width>>1)-1+x,(height>>1)-1+y);
x>>=1;
y>>=1;
gf_context_set_fgcolor( context, 0x00FF00);//green
x>>=1;
y>>=1;
gf_context_set_fgcolor( context, 0x0000FF);//blue
x>>=1;
y>>=1;
gf_context_set_fgcolor(context,0x000000);//black
x>>=1;
y>>=1;
gf_context_set_fgcolor(context,0xFFFFFF);//white
x>>=1;
y>>=1;
gf_context_set_fgcolor(context,0xFFFF00);//?
gf_draw_rect(context,(width>>1)-1-x,(height>>1)-1-y,(width>>1)-1+x,(height>>1)-1+y);...
RE: RE: background and foreground windows problem
07/30/2009 7:57 AM
post34887
The code in your test application doing the gf_layer_attach() specifies display_info.main_layer_index for the layer
index. With the iMX31 driver this value is 0 which corresponds to the Background window.
If you wish to use the Foreground window you will need to specify a layer_index of 1.
Note the iMX31 terms Background and Foreground have nothing to do with the setting of background or foreground color.
Sent: July 29, 2009 9:21 PM
Subject: Re: RE: background and foreground windows problem
int main() {
//device & display
gf_dev_t gdev;
int i;
//layer
gf_layer_t layer;
//surface
unsigned height;
unsigned width;
//context
return (-1);
} else {
else {
return (-1);
else{
return (-1);
} else {
return (-1);
return -1;
else{
return -1;
else{
int x,y;
x=400;
y=240;
x>>=1;
y>>=1;
x>>=1;
y>>=1;
gf_context_set_fgcolor( context, 0x0000FF);//blue...
