Forum Topic - gf_surface_attach returns GF_ERR_OK but img_surf is a NULL pointer.:
QNX 6.5.0 SP1
What would cause gf_surface_attach to return GF_ERR_OK, but not create a surface for the 'external' memory?
best regards
George Refseth
Re: gf_surface_attach returns GF_ERR_OK but img_surf is a NULL pointer.
Hello George,
What do you mean by "external memory"? Can you please provide a few examples of code?
Best regards
Andrey
Its the gf_splash application - available in several bsp's. Running on an arm-v7 target. Looks like there might be a
possibility for gf_surface_attach to return ok but not deliver a surface opaque pointer.
Any idea what (can) cause(s) this behaviour?
tia
George
As I understand you trying to show transparent image with gf_splash? To draw image with transparecy this application
uses gf_draw_blit2() with configured chroma key. Does your driver supports this feature?
Best regards
Andrey
