Forum Topic - Address of frame buffer:
Is there any way to find the address and size of the system frame buffer? I have an application that must save the
current content of the screen, use hardware encoding to turn it to jpeg and send it via ethernet to another device where
 it is decoded and shown on screen.
From my research, in order to do the above, I would need somehow to access the frame buffer, copy it into a local buffer
, apply some DCE functions and obtain the jpeg in a file I can then send. But I haven't found any reference to the
actual address where the buffer is stored (if I know this, I can easily use memcpy to access it).
As a final note, I don't want to make a screen shot (this was already done in a previous version of my app, one without
hardware encoding), but actually work with the raw frame buffer. Actual code or functions  would be of use, I'm trying
not to use other apps that may slow my device down (I'm working under strict cpu limitations).
Any info would be appreciated.
RE: Address of frame buffer
http://www.qnx.com/developers/docs/6.4.0/gf/dev_guide/api/gf_surface_get_info.html
vaddr in the info structure is the mapped in framebuffer of the provided surface.
From: Radu Stancu [mailto:community-noreply@qnx.com]
Sent: August-26-14 4:49 AM
To: advanced-graphics
Subject: Address of frame buffer
Advanced Graphics
http://community.qnx.com/sf/go/post111545
To cancel your subscription to this discussion, please e-mail advanced-graphics-unsubscribe@community.qnx.com
Perhaps you could mention which framework you're using? Derek's likely assuming GF because you're posting in the advance
 graphics forum, but you don't actually provide any hints of the framework.
-Joel
Sent: Tuesday, August 26, 2014 8:29 AM
To: 'advanced-graphics@community.qnx.com'
Subject: RE: Address of frame buffer
Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post111547
Re: RE: Address of frame buffer
I'm working on an embedded system for automotive that has omap 5 and qnx on it. My application is written in Qt 5.2  (I
render some objects, like cubes and such on 2 screens). The main thing I need to do is somehow capture a frame on one
screen and then proceed as I mentioned in the original post. The framebuffer approach was the first that came to mind,
as I need something raw for dce encode. I don't really need a solution in Qt, a separate program written in C would work
 as well, . But I'm kinda lost, because I'm not that familiar with qnx.
> assuming GF because you're posting in the advance graphics forum, but you
> -Joel
> From: Derek Leach [community-noreply@qnx.com]
> html
> surface.
> Hello,
> have an application that must save the current content of the screen, use
> device where it is decoded and shown on screen.
>  frame buffer, copy it into a local buffer, apply some DCE functions and
> to the actual address where the buffer is stored (if I know this, I can easily
> a previous version of my app, one without hardware encoding), but actually
>  trying not to use other apps that may slow my device down (I'm working under
> Advanced Graphics
> Advanced Graphics
RE: RE: Address of frame buffer
Posting to open Qt forum might provide a quick turnaround.  I would think they would have a Qt way of doing this.
Sent: August-26-14 10:17 AM
Subject: Re: RE: Address of frame buffer
> -Joel
> html
> provided surface.
> Hello,
> buffer? I have an application that must save the current content of
> ethernet to another device where it is decoded and shown on screen.
> access the  frame buffer, copy it into a local buffer, apply some DCE
> found any reference to the actual address where the buffer is stored
> done in a previous version of my app, one without hardware encoding),
> would be of use, I'm  trying not to use other apps that may slow my
> Advanced Graphics
> advanced- graphics-unsubscribe@community.qnx.com
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post111551
I'd suggest referring to the documentation for the product you're using to get more acquainted.
If you then have more specific questions, we could then probably more helpful.
-Joel
Sent: Tuesday, August 26, 2014 10:16 AM
> -Joel
> html
> surface.
> Hello,
> Advanced Graphics
> Advanced Graphics
Advanced Graphics
