Forum Topic - gf_context_set_pattern function:
Hi ,
from the help documents, it says the second parameter of this function is pattern which is A pointer to the bitmap
containing the pattern.
my question is how can I define the bitmap ?
Re: gf_context_set_pattern function
The pattern is a pointer to an array of characters defining the pattern bitmap.
This array should define an 8X8 single bit/pixel bitmap packing 8 pixels/byte, with no padding.
Hi Misha,
thanks for your help.
I have an another question, how can I use this 8x8 value combine with ROPs(gf_context_set_rop());
for example,
I want to draw an 8x8 rectangle and set all the needed values like this,
mypattern[8] = {0x00, 0x44, 0x00,0x11, 0x00,0x44, 0x00,0x11 };
fgcolor:    0xFFFF0000
bgcolor:   0xFF0000FF
rop:          GF_ROP_PDSnaon
 what is the formula to get the result ?
If I understand you correctly you should try something like this:
-- disable all ROP operation
-- set fgcolor to your "bgcolor"
-- draw a solid rectangle (gf_draw_rect()) where you need it, let's say @ X,Y
-- set the pattern
-- set the ROP
-- set fgcolor to your "fgcolor"
-- draw a solid rectangle again @ X,Y
