Forum Topic - Write data into draw context memory slowly!:
I write a program using draw context memory by the function PdCreateOffscreenContext(). This function returns a pointer
to a PdOffscreenContext_t. After that i use the function PdGetOffscreenContextPtr() to get a pointer to the shared
memory object. When i have that pointer i can change data in the context to blit them on the screen by the function
PgContextBlit(). However i had a problem with writing data back into the context, it was very slow. For example: ptr is
the pointer to context, d is a variable.
for(int i=0; i < CONTEXT_HEIGHT; ++i)
    for(int j=0; j < CONTEXT_WITH; ++j) {
       d = *(ptr + i * CONTEXT_WIDTH * 4 + j);(1)
      *(ptr + i * CONTEXT_WIDTH * 4 + j) = 2 * d; (2)
if i set CONTEXT_HEIGHT and CONTEXT_WIDTH small (about smaller than 256) the program run normal.
if i set CONTEXT_HEIGHT and CONTEXT_WIDTH biggerl (about 1024) the program run very slow.
I tried to test with bypassing either the line (1) or the line (2) and i realized that the line (2) made the program
very slow. Can you help me to solve it?
Re: Write data into draw context memory slowly!
This is most likely expected -- when you get a pointer to a video (dedicated) memory. The memory access is facilitated
by the graphics controller and is usually slow for reading (comparing to a RAM memory controller) and fast for writing.
What graphics adapter are you using?
Dear you!
I am using the graphics adapter Intel GFX. I used window OS to build
programs with the context memory and they always run normal, there were not
any problem. Do you have solutions for my problem? Can you help me. Please!
2011/5/31 Misha Nefedov <community-noreply@qnx.com>
> (dedicated) memory. The memory access is facilitated by the graphics
> Advanced Graphics
> http://community.qnx.com/sf/go/post86272
I bought a computer from Advantech, its name is ARK-6622H-18ZE. You can see
details about graphic adapter on website of Advantech. Thank you.
2011/5/31 Thắng Bùi Quý <bqthangcndt@gmail.com>
> Dear you!
>> Advanced Graphics
The code is for a chassis. Please post a link to the board/graphics adapter details.
This is the link which contains datasheet of ARK-6622H-18ZE:
http://www.alldatasheet.net/datasheet-pdf/pdf/327854/ADVANTECH/ARK-6622H-18ZE.html
and this is the link for the board:
http://buy.advantech.com/AIMB270G200A1E/AIMB270G200A1E/model-AIMB-270G2-00A1E.htm
> details.
> Advanced Graphics
> http://community.qnx.com/sf/go/post86276
1. What graphics driver are you using?
2. What version of the OS?
3. What is the output of 'pci -v' (relevant part only -- search for VGA)
4. What is the output of show_vesa ? (just the header -- not need for modes' descriptions).
