Forum Topic - What are the basics of font rendering?:
I'm sure this is my own failure to understand the obvious, but if somebody could give me some pointers it would be very
helpful.  The application program I am working on continually reads jpg and/or png files, manipulates them in various
ways, then writes out a bmp file, using the graphics framework.  There is no user interface.  Photon is not running. The
 application works fine, except that I now find I need to render text onto the images, and can't figure out even the
basic steps to do so.
That's my general problem, but far as specifics are concerned, I have two questions to start with:
1.  Given that Photon isn't being used, what software can I use as a font server, and what are the specifics of
obtaining and starting up that software outside of a Photon-related context?
2.  How does one interact with the font server within the context of the graphics framework to get the text rendered
into memory-buffered imagery?  The names of specific API functions would be very helpful.
Thanks!
Re: What are the basics of font rendering?
-- start 'phfont -d /usr/photon/font_repository' -- this will run the server -- you do not need photon
-- use PfAttach(), PfRender(), etc API to render the fonts -- http://www.qnx.com/developers/docs/6.5.0/topic/com.qnx.doc
.photon_lib_ref/pf-base.html
Re: What are the basics of font rendering? [bcc]
Thanks, Misha, that's very useful.  The platform I'm working on is
actually a CAR system that doesn't seem to have phfont on it, but if I
copy a copy of phfont over from QNX 6.5.0, it seems to run and not complain.
However ... as soon as my app tries to use any of the API's font-related
functions there's a segfault.  Recall that I'm not running Photon.  I
wonder if there's some kind of initialization I'm supposed to be doing
that would normally have been done by starting Photon?  Or, could a
versioning discrepancy in phfont be the problem?
Or perhaps I simply don't know what I'm doing in regard to text
rendering.  Is there a suitable coding tutorial somewhere?  (Remember
... I don't have any user interface here, so any tutorial that involves
displaying stuff in windows in Photon is of limited use to me.)
Thanks again!
doc.photon_lib_ref/pf-base.html
> Advanced Graphics
> http://community.qnx.com/sf/go/post85666
I am not aware of a Pf*() tutorial. I recommend starting with the sample code that is in PfRender() API docs.
Also check that:
-- you are running pfont,
-- check sloginfo,
-- see where the app is crashing.
Re: What are the basics of font rendering? [bcc] [bcc][auto-ip]
What is pfont? If you meant phfont, yes ps shows that it's running.
> Also check that:
> -- check sloginfo,
> Advanced Graphics
> http://community.qnx.com/sf/go/post85678
phfont ;-)
Thanks, Misha, I hadn't gotten as far as trying to render the text, so I
hadn't yet become aware of that sample code.  More on that below.
> Also check that:
Here's what "ps -Af | grep phfont" says:
     0    1163315          1  - May16 ?        00:00:00 phfont -d
> -- check sloginfo,
As far as sloginfo is concerned, the following lines seem to be the only
relevant ones:
May 16 07:53:10    1     8     0 phfont: init...
May 16 07:53:10    1     8     0 phfont: initialized.
May 16 07:53:10    1     8     0 phfont: '/dev/phfont[<32|64>]' server
installed.
As I understand it, what the sample code in the PfRender() docs say to
do is:
   1. Run PfAttach().
   2. Run PfFindFont().
   3. Run PfRender().
I segfault the very first time I hit PfFindFont().  Here's the relevant
code-snippet from my program:
   FontServer = PfAttach (NULL, 0);
   if (FontServer == NULL)
       fprintf (stderr, "Cannot attach to font server.\n");
       goto Error;
   for (i = 0; i < 3; i++)
     for (j = 0; j < NUM_FONT_SIZES; j++)
         int FontSize;
         FontID *ID;
         FontSize = MIN_FONT_SIZE + INC_FONT_SIZE * j;
         ID = PfFindFont (FontDescriptions[i], FontStyles[i],
             FontSize);
         if (NULL == ID)
             fprintf (stderr, "Cannot find font %s size %d style 0x%X\n",
                 FontDescriptions[i], FontSize, FontStyles[i]);
         FontStructures[i]->ID = ID;
At the point where the segfault occurs in PfFindFont():
    * FontDescriptions[i] is a pointer to the string "ronsanss", which
      is a TrueType font that I've installed and is known-good (at least
      in Linux).  When I say I've "installed" it, I mean that I hope I
      installed it correctly and that one of the lines in
      /usr/photon/font_repository/fontdir is "ronsanss,0@RonSans.ttf,Ron
      Sans,0,,000D-FFFD,p,228x151,4508K".  Please recall that I'm not
      running Photon, so I'm not aware of any good way to know that the
      installation was correct until my app actually works.
    * FontStyles[i] is 16 (PF_STYLE_ANTIALIAS).
    * FontSize is 10.
> Advanced Graphics
Oops! I was a bit to hasty in the code snippet I sent in my last
message.  Here's a better one:
       goto Error;
         int FontSize;
         FontID *ID;
         FontName Description;
         if (NULL == PfGenerateFontName (
             FontDescriptions[i], FontStyles[i], FontSize, Description))
             fprintf (stderr, "Cannot get font name %s size %d style
0x%X\n",
             return (1);
         ID = PfFindFont (Description, FontStyles[i], FontSize);
         if (NULL == ID)
             return (1);
Here the segfault occurs as soon as PfGenerateFontName() is hit.  The
arguments to PfGenerateFontName() correspond to the description I gave
for the arguments of PfFindFont() in my last message.  In point of fact,
the segfault occurs if I simply run the sample code in the
PfGenerateFontName() doc:
       goto Error;
       char szHelvetica12[MAX_FONT_TAG];
       if (PfGenerateFontName ("Helvetica", PF_STYLE_BOLD, 12,
szHelvetica12)
           == NULL)
           perror ("Unable to find font");
This is likely that you are trying to use photon wrapper functions, and since you are not connected to photon they fail.
Change the code to use Pf*Cx() API. For example PfGenerateFontNameCx(). It takes an extra parameter which is a struct
_Pf_ctrl * -- the one returned by the PfAttachCx().
Well, you're right that it doesn't segfault with
PfGenerateFontNameCx().  The next problem is that no matter what
pkgDescription argument I plug into PfGenerateFontNameCx(), the function
always returns NULL.  I guess the names from the fontdir file are not
what is supposed to be in pkgDescription.  Certainly, the string
"Helvetica" as given in the sample code doesn't work.  How can I find a
valid pkgDescription to plug in?
fail.
> Advanced Graphics
> http://community.qnx.com/sf/go/post85711
Forget my last message.  I was just being dumb, and didn't pass
PfGenerateFontNameCx() the right struct.
fail.
> Advanced Graphics
So Misha, as I said before, you were right and PfGenerateFontNameCx()
does not segfault.  But I must still be failing to understand some basic
point.  Right now I'm trying the following code:
   FontServer = PfAttachCx (NULL, 0);
       goto Error;
#if 1
       char *FontName = "Courier10 BT";
       FontSize = 10;
       if (NULL == PfGenerateFontNameCx (FontServer, FontName, 0, FontSize,
           Description))
           fprintf (stderr, "Cannot get font name %s size %d style 0x%X\n",
               FontName, FontSize, 0);
           return (1);
       ID = PfFindFontCx (FontServer, Description, 0, FontSize);
       if (NULL == ID)
           perror (strerror (errno));
           return (1);
#endif
The call to PfAttachCx() succeeds.  The call to PfGenerateFontNameCx()
succeeds ... with the code shown, it provides a Description[] of
"courier10bts10".  However, PfFindFontCx() fails with a return value of
NULL.  errno is set to ESRCH, indicating no font found.  I've tried
various other fonts as well, with no luck.
What am I missing here?
fail.
> Advanced Graphics
The 'Description' should be replaced with 'FontName' when calling the PfFindFont(). The PfFindFont() is similar to
PfGenerateFontName(), it only returns FontID. I am not sure why you need it.
The 'Description' you got from the Generate function is good to be used with the subsequent PfRenderCx().
Well, I was simply following the sample code in the PfRenderCx() API
doc, as you suggested.  The sample code calls PfFindFontCx().
Personally, I'm willing to do without it, even though I don't see why it
should be failing.
Okay, I think you're suggesting something like this:
   pf_point_t pp = { 50, 50 };
   int FontSize = 10;
   ... check for error ...
Description))
       ... error ...
   i = PfRenderCx (FontServer, FontServer, Description, 0L, 0L, "Hello,
world!", 0,
        0, &pp, NULL, Callback);
This code fails when it reaches PfRenderCx().  The error message
displayed by "perror(strerror(errno))" is "Invalid argument".
> Advanced Graphics
> http://community.qnx.com/sf/go/post85727
Hard to tell. Can you please post the entire source file -- for me to try?
Here's code that fails for me as described.  I compiled it with
"ntox86-gcc -o FontTest FontTest.c -lph" and ran the font server with
"phfont -d /usr/photon/font_repository -D /usr/photon/font_repository".
#include <stdio.h>
#include <errno.h>
#include <photon/Pf.h>
void
Callback (void *ctx, const pf_point_t *pos, const FontRender *fr)
   fprintf (stderr, "Callback: %d,%d\n", pos->x, pos->y);
   fprintf (stderr, "Callback: %d,%d %d,%d %d, %d, %d, %p\n",
       fr->size.x, fr->size.y, fr->offset.x, fr->offset.y,
       fr->width, fr->bpl, fr->bpp, fr->bmptr);
int
main (void)
   char *MyFontName = "Courier10 BT";
   int FontSize = 10;
   int i;
   struct _Pf_ctrl *FontServer = NULL;
   FontID *ID;
       return (1);
   if (NULL == PfGenerateFontNameCx (FontServer, MyFontName, 0,
           MyFontName, FontSize, 0);
       return (1);
                   "Hello, world!", 0, 0, &pp, NULL, Callback);
   fprintf (stderr, "PfRenderCx() returned %d\n", i);
   if (i)
     fprintf (stderr, "%s\n", strerror (errno));
   return (0);
> Advanced Graphics
> http://community.qnx.com/sf/go/post85742
Yes, I got this. The problem is that we asked to NO rendering buffer when doing th PfAttachCx(). Give it a number, for
example:
PfAttachCx( NULL, 32*1024 );
The size of the buffer should depend on how large the strings and the font size are.
Thanks, Misha.  It does seem to do something now.
 example:
> Advanced Graphics
> http://community.qnx.com/sf/go/post85785
