Forum Topic - cleaning up an img_t* in C++:
So, i've been working with the IMG library in C++ and I'm working on closing down memory leaks.
The way i've been creating my img_t objects is:
img_t* OrigImage = new img_t();
This works well enough until I start doing my house cleaning:
if (OrigImage->access.direct.data != NULL) {
	delete OrigImage->access.direct.data;
if (OrigImage->palette != NULL) {
	delete OrigImage->palette;
delete OrigImage;
This code works pretty good, except when there's palette information...and then it crashes.
So, anybody know a better way to fully clean up an img_t* ?
RE: cleaning up an img_t* in C++
try this:
if (img->flags & IMG_DIRECT) {
    free(img->access.direct.data);
    img->flags &= ~IMG_DIRECT;
    if (img->flags & IMG_PALETTE) {
        img->flags &= ~IMG_PALETTE;
} else if (img->flags & IMG_PALETTE) {
    free(img->palette);
From: Michael Briggs [mailto:community-noreply@qnx.com]
Sent: February 23, 2011 1:09 PM
To: advanced-graphics
Subject: cleaning up an img_t* in C++
delete OrigImage;
Advanced Graphics
http://community.qnx.com/sf/go/post83429
Derek -
Thanks for the sample.  It worked perfectly...and helped demonstrate my lack of deep understanding of the img_t
structure. :-)
I made a cleanup function that passes in an img_t* item, runs your code, then deletes the img_t* item.
- Mike
From: Derek Leach [mailto:community-noreply@qnx.com]
Sent: Wednesday, February 23, 2011 1:20 PM
Subject: RE: cleaning up an img_t* in C++
try this:
    free(img->palette);
delete OrigImage;
Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post83432
Re: RE: cleaning up an img_t* in C++
Hi Derek,
I have a question with regard to img_t but in regard to who is allocating memory for access.direct.data pointer when
using setting the IMG_DIRECT flag?  Will  the img_load_file() allocate memory for it?
I am trying to read a .png file, make some modification to the file and then save it as new .png file.  However, when I
set the IMG_DIRECT flag, my  system hangs.  If I don't set the IMG_DIRECT flag, the file is loaded correctly.
I am using QNX 6.4.1 on the host and the same version running on a VM target.
I appreciate it if you can give me pointer on where the problem could be.
RS.
You cannot mix delete and malloc. Also in C++ it`s legal to do a delete on a NULL, hence you can get rid of the ifs.
> -----Message d'origine-----
> De : Michael Briggs [mailto:community-noreply@qnx.com]
> Envoyé : 23 février 2011 13:09
> À : advanced-graphics
> Objet : cleaning up an img_t* in C++
> down memory leaks.
> delete OrigImage;
> then it crashes.
> Advanced Graphics
Mario -
While, yes, it is syntactically legal to do a delete on a NULL, in QNX on ARM-LE v7 it generates a core dump of the file
 due to being an illegal function.  So that's why I was protecting against NULLs.
However, Derek's solution was much more elegant and does the job just fine.
- Mike
Sent: Wednesday, February 23, 2011 2:17 PM
> down memory leaks.
> delete OrigImage;
> then it crashes.
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post83439
