Forum Topic - Is there any frame buffer concept in QNX Display Driver ? :
Hi Experts,
Is there any frame buffer concept in QNX for display driver. I am working on porting display driver on omap2430. I
couldn't find any omap2430 bsp on the website. I looked at the IMX21 bsp. It has the display driver reference in devg
folder. I kind of got the idea how display driver is populating function pointer in DISP_ADD_FUNCTION and some of them
are implemented in them, but I couldn't see any code where it is mapping a memory from SRAM/SDRAM as part of frame
buffer. I saw the config file imx21.conf as well but could not the see the reference of memory as frame buffer.
Do we have framebuffer concept in QNX? How is the display driver rendering the image on the LCD panel?
I would appreciate the reply. I am using QNX6.5.
Regards
Re: Is there any frame buffer concept in QNX Display Driver ?
Takshi Pandey wrote:
> Hi Experts,
http://community.qnx.com/sf/projects/qnx_community_sdl_project/
--Armin
http://www.steinhoff-automation.com
> Regards
> Advanced Graphics
> http://community.qnx.com/sf/go/post83127
Thanks Armin for the reply. The link that you shared seems that SDL takes care of everything as far as playing Audio/
Video is concern. But I somehow could not relate this to the devg-xxx.so display driver. I could not see any references
to SDL libraries in the display driver.
The surprising this is that I could see something on the OMAP2430 LCD panel (running a simple demo app) despite not
seeing any references to SDL in my display driver.
My question are :
1) From where the display driver is rendering the image?
2) What part of the display driver code is responsible for this?
3) How should we link to SDL library in order to get the Framebuffer for the image rendering?
4) Where is the code which is mapping the physical memory for the frame buffer in devg-driver?
regards,
> > Hi Experts,
>  porting display driver on omap2430. I couldn't find any omap2430 bsp on the
> devg folder. I kind of got the idea how display driver is populating function
> pointer in DISP_ADD_FUNCTION and some of them are implemented in them, but I
> frame buffer. I saw the config file imx21.conf as well but could not the see
> --Armin
> > Regards
> > Advanced Graphics
> My question are :
SDL is using low level calls of the Photon API in order to create
something like a frame buffer interface.
(~/src/video/photon/SDL_ph_video.c )
Doesn't the BSP of the OMAP2430 support Photon ?
--Armin
I could run the 2D demo app VSYNC and it is running fine. Although, I need to slay the Photon app for this VSYNC to run
coz it goes and attach to the same layer that Photon runs on otherwise fails saying layer attach failed.
I could not see (~/src/video/photon/SDL_ph_video.c ) in my entire project and thats what is surprising me how the
display is working.
I am working with OS QNX6.5.
> care of everything as far as playing Audio/Video is concern. But I somehow
> references to SDL libraries in the display driver.
> (running a simple demo app) despite not seeing any references to SDL in my
> display driver.
> > My question are :
> --Armin
run coz it goes and attach to the same layer that Photon runs on otherwise fails saying layer attach failed.
display is working.
OK ... Photon is available.  So download the sources of SDL 1.3 and
recompile it and you will get a "frame buffer"
--Armin
> Regards,
>> display driver.
>>> My question are :
>> --Armin
> Advanced Graphics
> http://community.qnx.com/sf/go/post83135
Thanks Armin and sorry for the late response.
Can you point me to any bsp which has the reference of SDL?
How do I add this SDL into my bsp? How am I going to link my bsp with this SDL?
And the last question. If I don't have SDL how am I seeing the images or able to play the demo apps presently?
> to slay the Photon app for this VSYNC to run coz it goes and attach to the
> and thats what is surprising me how the display is working.
> --Armin
> > Regards,
> any
> panel
> >> display driver.
> >>> My question are :
> >> --Armin
> > Advanced Graphics
The SDL project (http://www.libsdl.org ) isn't part of any BSP ... but
it is applicable with a QNX BSP if Photon is available.
Since version 0.8 exists support for Linux and ARM ... so it's not
rocket science to bring it down to QNX 6.x. and ARM.
There are a lot of demos at http://www.libsdl.org ...
--Armin
> Regards,
>> --Armin
>>> Regards,
>> any
>> panel
>>>> display driver.
>>>>> My question are :
>>>> --Armin
>>> Advanced Graphics
> Advanced Graphics
> http://community.qnx.com/sf/go/post83153
RE: Is there any frame buffer concept in QNX Display Driver ?
Hi Takshi,
I am just hijacking this thread for a minute ... :)
I need
to the
failed.
project
You can run vsync on another layer if your devg supports multi-layers:
vsync 0   <- layer 0
vsync 1   <- layer 1
vsync 2   <- layer 2
OR like I mentioned to Raj, you can create a hybrid GF/Photon
application as well,
which means you can run all those GF applications on the same layer as
Photon, in
a Photon window.
Takshi and Raj, I still do not have a clear understanding about what you
want with "video".
Do you just want to play a video file, like a .mpg ... or do you want to
stream it
from a video capture device on your hardware, or do you want to stream a
MPEG stream
from a network connection?
Armin's SDL is great ... I am just trying what to understand what you
are asking for.
-Derek
>> --Armin
>>> Regards,
SDL takes
somehow
not see
>> any
LCD
>> panel
SDL in my
>>>> display driver.
>>>>> My question are :
>>>> --Armin
>>> Advanced Graphics
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post83157
