Forum Topic - Display Hanging after Pterm Utility:
Dear All,
I am trying to port display driver on QNX for OMAP2430 hardware. I have configured LCD controller, Framebuffer etc. I am
 seeing PTERM windows on the LCD panel and the cursor blinking but thats it. I cannot type any commands in "minicom"
neither in pterm window(needless to say there is no input driver running). Is Photon expecting an input driver? If it is
, then display driver is depending upon the input driver.
One more thing I read on QNX website that don't use "layer_flushrect()" API. I was seeing this API being called
continuously, so I commented this API. May I know what does this API do? Is it the same as "blitting"?
I have attached the relevant files for your kind reference.
I would appreciate the help very much.
Attachment: Text files.tar.gz 7.34 KB
RE: Display Hanging after Pterm Utility
What version of the OS are you running on?
layer_flushrect() is basically a "hack" for drivers that have virtual
layers, and or an optimization for layers if their GPU can be fine tuned
that way.  It is not necessary, and you should not populate the callout.
Input is not required, but you would need it to type into a pterm.  btw,
you would see this being called continually if you had a blinking
cursor.
I am not sure what you mean by minicom, I assume you mean a terminal
connected to the serial port?
Maybe something is running ready?  Run you terminal at a higher
priority, and check the state of the system.
If it is a serial terminal, you will need to run the serial driver at a
higher priority as well.
From: Raj Pandey [mailto:community-noreply@qnx.com]
Sent: February 8, 2011 5:34 AM
To: advanced-graphics
Subject: Display Hanging after Pterm Utility
Dear All,
configured LCD controller, Framebuffer etc. I am seeing PTERM windows on
commands in "minicom" neither in pterm window(needless to say there is
no input driver running). Is Photon expecting an input driver? If it is,
API. I was seeing this API being called continuously, so I commented
"blitting"?
Advanced Graphics
http://community.qnx.com/sf/go/post82973
Re: RE: Display Hanging after Pterm Utility
Thanks Derek for the reply.
Sorry for not mentioning the OS version. I am running 6.5.
As I mentioned I am not populating the layer_flushrect(), but you are right I could be getting the continuous calls
because my cursor is blinking.
You are absolutely right about "minicom". I am using a serial terminal to launch the Pterm utility. I am not sure on
what priority my serial driver is running on.
I would appreciate Derek if you could look at the attached files and see if there is something wrong in that.
RE: RE: Display Hanging after Pterm Utility
Are you running the pterm in the background?  pterm &
Sent: February 8, 2011 12:26 PM
Subject: Re: RE: Display Hanging after Pterm Utility
right I could be getting the continuous calls because my cursor is
blinking.
to launch the Pterm utility. I am not sure on what priority my serial
Advanced Graphics
http://community.qnx.com/sf/go/post82996
Re: RE: RE: Display Hanging after Pterm Utility
No Derek, it is running in foreground.
## START OF BUILD SCRIPT
[image=0x80010000]
[+compress]
#[virtual=armle,binary] .bootstrap = {
[virtual=armle,raw] .bootstrap = {
	startup-omap2420sdp -L -v -U1 -le 0xA1F00000 0x01000000
	## PATH set here is the *safe* path for executables.
	## LD_LIBRARY_PATH set here is the *safe* path for libraries.
	##     i.e. These are the paths searched by setuid/setgid binaries.
	##          (confstr(_CS_PATH...) and confstr(_CS_LIBPATH...))
	PATH=:/proc/boot:/bin:/usr/bin:/bin:/usr/photon/bin
        LD_LIBRARY_PATH=:/proc/boot:/lib:/usr/lib:/lib/dll \
	PHOTON_PATH=/usr/photon PHOTON=/dev/photon PHFONT=/dev/phfont procnto-v6
[+script] .script = {
	procmgr_symlink ../../proc/boot/libc.so.3 /usr/lib/ldqnx.so.2
	display_msg Welcome to QNX Neutrino Trunk on the Texas Instruments OMAP2430SDP Board
	## SERIAL driver
	devc-seromap -e -F -b57600 -c48000000/16 0x4806A000^2,72
	waitfor /dev/ser1 4
	reopen /dev/ser1
	slogger
	pipe
	## NAND_ETFS driver
	#display_msg Starting etfs driver...
	#fs-etfs-omap2420 -r4096
	## NETWORK driver
	#display_msg Starting on-board ethernet with TCP/IP stack...
	#io-pkt-v4 -dsmc9000 ioport=0x08000300,irq=188 -ptcpip
	#waitfor /dev/io-net/en0 4
	## I2C driver
	##  - Required for both USB and AUDIO
	display_msg Starting I2C driver...
	i2c-omap59xx -p0x48072000 -i56
	waitfor /dev/i2c0 5
	## USB driver
	##  - Requires the I2C driver to be running
	#display_msg Starting USB stack...
	#omap2420sdp_usb_init
	#io-usb -dohci ioport=0x4805e000,irq=78
	## input
	#display_msg Starting Keypad driver...
	#devi-omap_keypad keypad
	## These env variables are inherited by all the programs which follow
	SYSNAME=nto
	PATH=:/proc/boot:/bin:/usr/bin:/opt/bin:/usr/photon/bin
	PHOTON=/dev/photon
	PHFONT=/dev/phfont
	TERM=qansi
	HOME=/
	## GRAPHICS
	display_msg Starting io-display...
	io-display  -dvid=0,did=0
	waitfor /dev/io-display 10
	## Photon and Phfont
	## - NOTE: Photon and phfont MUST be started before the GRAPHICS driver
	display_msg Starting Photon...
	Photon &
	waitfor /dev/photon 10
	display_msg Starting Phfont...
	Phfont &
	waitfor /proc/boot/phfont 10
        display_msg...
RE: RE: RE: Display Hanging after Pterm Utility
Maybe I misunderstand, but how do you expect to type on the serial
console, if pterm is running in the foreground on the console?  pterm
does not daemonize itself.  I am not even sure that bkgdmgr daemonizes
itself either ... add a & to the end of those lines.
Sent: February 8, 2011 9:32 PM
Subject: Re: RE: RE: Display Hanging after Pterm Utility
[image=0x80010000]
[+compress]
binaries.
procnto-v6
	## SERIAL driver
	waitfor /dev/ser1 4
	reopen /dev/ser1
	slogger
	pipe
	## NAND_ETFS driver
	## NETWORK driver
	## I2C driver
	waitfor /dev/i2c0 5
	## USB driver
	## input
follow
	SYSNAME=nto
	PHOTON=/dev/photon
	PHFONT=/dev/phfont
	TERM=qansi
	HOME=/
	## GRAPHICS
	display_msg...
I got the Pterm working. I ran the Pterm in background and I could see the blinking cursor and I can type the commands
in serial terminal.
I created one simple app to draw a rectangle and I am trying to launch this app from the serial terminal and not the
Pterm. I have put that application in /src/utils/ folder. The application is there in the image.
I have two question regarding this.
i) Do I need to launch the app from the Pterm?
   If yes, then I will need an input driver.
ii) Can I launch that App from the serial terminal?
I tried doing it but it doesn't draw the rectangle.
The "Sloginfo" says that gf_draw_begin() failed with gf_errno 1.
Does anybody know why I got this error? I would appreciate the reply.
Note:
I could draw the rectangle by typing following command on pterm "pterm -x10 -y10 -height100 -width100".
One final question. Is there a way to display the QNX home screen on the LCD panel? If yes, then how?
> [image=0x80010000]
> [+compress]
> OMAP2430SDP Board
> 	## SERIAL driver
> 	waitfor /dev/ser1 4
> 	reopen /dev/ser1
> 	slogger
> 	pipe
> 	## NAND_ETFS driver
> 	## NETWORK driver
> 	## I2C driver
> 	waitfor /dev/i2c0 5
> 	## USB driver
Is this rectangle application a GF or a Photon application?
No, there is no need to run it from pterm.
Sent: February 9, 2011 8:49 AM
the blinking cursor and I can type the commands in serial terminal.
this app from the serial terminal and not the Pterm. I have put that
image.
Note:
> [image=0x80010000]
> [+compress]
binaries.
procnto-v6
Instruments
> OMAP2430SDP Board
> 	## SERIAL driver
> 	waitfor /dev/ser1 4
> 	reopen /dev/ser1
> 	slogger
> 	pipe
> 	## NAND_ETFS driver
> 	## NETWORK driver
> 	## I2C driver
> 	waitfor /dev/i2c0 5
Re: RE: RE: RE: Display Hanging after Pterm Utility
Thanks for the reply Derek. It is a GF application and not the Photon one.
> image.
> Note:
> Regards,
> > [image=0x80010000]
> > [+compress]
> binaries.
> procnto-v6
> Instruments
> > OMAP2430SDP Board
> > 	## SERIAL driver
> > 	waitfor /dev/ser1 4
> > 	reopen /dev/ser1
> > 	slogger
> > 	pipe
> > 	## NAND_ETFS driver
> > 	## NETWORK driver
RE: RE: RE: RE: Display Hanging after Pterm Utility
Ok, you will need to run it on a different layer than Photon, or turn
your application into a Photon/GF hybrid application.  Examples of
hybrid applications can be found at:
http://community.qnx.com/sf/frs/do/viewRelease/projects.graphics/frs.pho
ton.gf_ph_2d
Sent: February 9, 2011 11:37 AM
Subject: Re: RE: RE: RE: Display Hanging after Pterm Utility
one.
> image.
> Note:
the
> Regards,
> > [image=0x80010000]
> > [+compress]
> binaries.
> procnto-v6
> Instruments
> > OMAP2430SDP Board
> > 	## SERIAL driver
> > 	waitfor /dev/ser1 4
> > 	reopen /dev/ser1
> > 	slogger
> > 	pipe
Re: RE: RE: RE: RE: Display Hanging after Pterm Utility
Thanks Again Derek for the reply. Appreciated it very much. I'll work on hybrid application tomorrow.
Is there a way to display QNX homescreen like all the other OS does ,e.g Linux shows a "penguin" or WindowsCE/Mobile
shows their logo during/after boot up?
Raj
> ton.gf_ph_2d
> one.
> > image.
> > Note:
> the
> > Regards,
> > > [image=0x80010000]
> > > [+compress]
> > binaries.
> > procnto-v6
RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Depends how soon you want it to come up ... do you want it immediate, or
once io-display is running, or is it OK to wait until Photon is booted?
Immediate is much more difficult.
If once io-display is running, just run a GF application on a layer that
is behind the layer that Photon will use (if you have more than one
layer).  You can slay it off later.
If after Photon has booted, just run you Photon application before any
other Photon applications.
Sent: February 9, 2011 12:20 PM
Subject: Re: RE: RE: RE: RE: Display Hanging after Pterm Utility
Linux shows a "penguin" or WindowsCE/Mobile shows their logo
Raj
> ton.gf_ph_2d
> one.
see
launch
> > image.
reply.
> > Note:
"pterm
> the
> > Regards,
> > > [image=0x80010000]
> > > [+compress]
Re: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Thanks Derek.
Primarily we would have liked to do this during startup but now we abandon the idea. Now we want to do it once the
Photon is up and display driver is running.
I am assuming Photon is running on the main layer, layer=0. I tried with the hybrid app that you shared yesterday but
could not see any thing on the LCD panel. Looking at the log it seems the GF app is trying to run on the layer=1.
Pasting excerpt from the log after launching "gf-ph-2d" app.
# gf-ph-2d
Raw Widget: width = 235, height = 166
+devg_get_miscfuncs
-devg_get_miscfuncs
omap_module_info TI OMAP 35xx display Controller
omap_alloc_surface ++
omap_get_alloc_info ++
**************PdCreateOffscreenContextGF(): No such process
omap_layer_update_begin ++
omap_layer_set_surface ++
DISP_LAYER_FORMAT_RGB565
omap_layer_set_surface --
omap_layer_update_end ++
omap_layer_program ++
Video layer1 no scaling widthomap_layer_program
OMAP_LAYER_VID1
omap_layer_program --
omap_layer_update_end --
demarked the error text in the log. Why I got this error?
the sloginfo is :
# sloginfo
Jan 01 00:00:09    1     8     0 phfont.so: init...
Jan 01 00:00:09    1     8     0 phfont.so: initialized.
Jan 01 00:00:09    1     8     0 phfont.so: '/dev/phfont[<32|64>]' server installed.
Jan 01 00:00:11    6     8     0 omap_set_mode QVGA mode
Jan 01 00:00:11    6     8     0 omap_set_mode Use custom timing
Jan 01 00:00:11    6     8     0 omap_layer_query Layer unknown, (no more layers, maybe end of layer query)
Jan 01 00:00:11    6     8     0 omap_layer_program VIDEO 1
Jan 01 00:00:19    6     8     0 omap_layer_program VIDEO 1
If my assumptions are right, by default photon starts on layer=0(GFX), any 2D app starts on layer=1(Video1) and 3D
starts on layer=2(Video2).
I was trying to display one JPEG image on the LCD panel and reading through the QNX docs I got to know that I will need
"img_decode_simple" to draw the image. I do have libimg.so in my image and do see the entries for various image formats
in img.conf file.
Right now, I do not have "img_decode_simple" utility and I heard it comes with Advanced Graphics.
How do I get this utility to draw some image on the LCD panel. I would appreciate if you can clarify few of my doubts.
Raj
> Regards,
> Raj
> > ton.gf_ph_2d
> > From: Raj Pandey...
RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Is there any gf_layer_attach calls in the gf-ph-2d code?  I don't
believe it attaches directly to any layer ...
Sent: February 10, 2011 11:51 AM
Subject: Re: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Thanks Derek.
abandon the idea. Now we want to do it once the Photon is up and display
driver is running.
the hybrid app that you shared yesterday but could not see any thing on
on the layer=1. Pasting excerpt from the log after launching "gf-ph-2d"
app.
# gf-ph-2d
+devg_get_miscfuncs
-devg_get_miscfuncs
OMAP_LAYER_VID1
the sloginfo is :
# sloginfo
server installed.
any 2D app starts on layer=1(Video1) and 3D starts on layer=2(Video2).
through the QNX docs I got to know that I will need "img_decode_simple"
entries for various image formats in img.conf file.
Raj
or
booted?
that
on
,e.g
> Regards,
> Raj
> > Ok, you will need to run it on a different layer than Photon,...
Re: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
You are right Derek, there is no call to attach with any layer in the gf-ph-2d code.
So, what went wrong. Why I can't see the gf-ph-2d app running?
Do you suspect anything wrong with my settings? Be it display.conf/omap35xx.conf or the build file. I need to mention
one thing that I added layer=0 entry in the photon part of the display.conf file.
Raj
> Thanks Derek.
> driver is running.
> app.
> # gf-ph-2d
> +devg_get_miscfuncs
> -devg_get_miscfuncs
> OMAP_LAYER_VID1
> the sloginfo is :
> # sloginfo
> server installed.
> Regards,
> Raj
> or
> booted?
> that
> > is behind the layer that Photon will use (if you have more...
RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
ok, Photon is running, correct?  Are you running it as root?  By
default, all GF applications must run as root user.
Sent: February 10, 2011 12:18 PM
Subject: Re: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
gf-ph-2d code.
display.conf/omap35xx.conf or the build file. I need to mention one
file.
Raj
> Thanks Derek.
display
> driver is running.
with
on
"gf-ph-2d"
> app.
> # gf-ph-2d
> +devg_get_miscfuncs
> -devg_get_miscfuncs
> OMAP_LAYER_VID1
> the sloginfo is :
> # sloginfo
> server installed.
"img_decode_simple"
> Regards,
> Raj
> > Depends how soon you want it to come up ... do you...
Re: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
I guess Photon is running alright. All I see is a window with some color on LCD panel along with a command prompt
terminal just like a serial console. What will be the best way to check if the Photon is running perfectly?
Also, how do I run all the GF apps with root privilage?
Derek, my 2nd question was do I really need "img_decode_simple" utility to draw a bmp/jpg/gif image? If yes then how do
I get it?
Raj
> gf-ph-2d code.
> file.
> Regards,
> Raj
> > Thanks Derek.
> display
> > driver is running.
> with
> on
> "gf-ph-2d"
> > app.
> > # gf-ph-2d
> > +devg_get_miscfuncs
> > -devg_get_miscfuncs
> > OMAP_LAYER_VID1
> > the sloginfo is :
> > # sloginfo
> > server installed.
> > Jan 01 00:00:19    6     8     0...
RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
If you can see your pterm, it is running OK.
Yes, GF apps need root priviledge, or you need to set up an access
group, see the documentation for io-display.
The binary for img_decode_simple should be shipped, under /usr/bin, or
do you mean the source?
Sent: February 10, 2011 12:42 PM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm
Utility
on LCD panel along with a command prompt terminal just like a serial
perfectly?
to draw a bmp/jpg/gif image? If yes then how do I get it?
Raj
Utility
> gf-ph-2d code.
display.conf
> file.
> Regards,
> Raj
> > Thanks Derek.
> display
> > driver is running.
> with
> on
run
> "gf-ph-2d"
> > app.
> > # gf-ph-2d
> > +devg_get_miscfuncs
> > -devg_get_miscfuncs
> > OMAP_LAYER_VID1
> > the sloginfo is :
> > # sloginfo
Re: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Thanks. It means Photon is running OK.
I guess I got the idea of running the app in access group.
Is it that we need to put the gf-ph-2d app in the build file under the display driver group where all the other default
apps like, vsync, pterm, egl-gears are?
I am definitely not talking about the source code of img_decode_simple. I'll just check if we have this under /usr/bin
folder.
Thanks again Derek. Very much appreciated your help.
Raj
> Utility
> perfectly?
> Regards,
> Raj
> Utility
> > gf-ph-2d code.
> display.conf
> > file.
> > Regards,
> > Raj
> > > Thanks Derek.
> > display
> > > driver is running.
> > with
> > on
> run
> > "gf-ph-2d"
> > > app.
> > > # gf-ph-2d
> > > +devg_get_miscfuncs
> > > -devg_get_miscfuncs
Derek, I found the img_decode_simple app. I followed the procedures mentioned on the QNX website link "working with
images". I edited the img.conf file to have the entries for JPEG and BMP only. Added the img_decode_simple binary into
the target as well as added the jpg/bmp files for the drawing. I added this line :
into the build script so that it starts the drawing as soon as photon/io-display/io-graphics starts up and running.
However, I am getting this error
gf_setup() failed with error 8 which means there is something wrong with the format.
My display resolution is 240x320 and I am trying with images (125x94/300x282 as I couldn't find the image with exact
240x320 resolution).
Do you know what is wrong?
regarding the hybrid apps that you shared, I am not able see anything on the LCD panel after running gf-ph-2d & gf-ph-3d
 app.
gf-ph-2d complains about "PdCreateOffscreenContextGF(): No such process" and
gf-ph-3d complains saying "PdCreateOffscreenContextGF(): failed".
But the gf-gl_pg_demo app runs perfectly and I could see the gears moving with some text on the top as well.
Please tell what is wrong I am doing.
RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
I will check next week, I do not have time today.
Sent: February 11, 2011 6:49 AM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm
Utility
mentioned on the QNX website link "working with images". I edited the
img_decode_simple binary into the target as well as added the jpg/bmp
photon/io-display/io-graphics starts up and running. However, I am
getting this error
the format.
(125x94/300x282 as I couldn't find the image with exact 240x320
resolution).
the LCD panel after running gf-ph-2d & gf-ph-3d app.
and
Advanced Graphics
http://community.qnx.com/sf/go/post83110
Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Hi Derek,
did u get a chance to look into this issue that I am running in?
> Utility
> getting this error
> the format.
> resolution).
> and
> Regards,
> Advanced Graphics
RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
not yet, I just got to work.
Sent: February 13, 2011 9:29 PM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after
Pterm Utility
Hi Derek,
Pterm
> Utility
> getting this error
with
> the format.
> resolution).
on
process"
> and
> Regards,
> Advanced Graphics
Advanced Graphics
http://community.qnx.com/sf/go/post83129
Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Derek, no need for you to spend your time on img_decode_simple issue. Just got that stuff working today. I slayed the
Photon app and then run "img_decode_simple my.jpg" and I was able to draw the image on the LCD panel.
I just saw another thread inquiring about the FRAME BUFFER concept in QNX display driver.
This one thing is baffling me as well. Although I can do almost everything with my display driver ,i.e, draw images, run
 2D/3D demo apps. The only thing pending is playing a video.
Just wanted to know where are we defining the memory for the frame buffer. Is it the one in build file, the parameters
we pass to the start up script like omap3530 -L 0x87E00000 0x00020000 ?
I haven't see any reference of frame buffer in the devg code.
The other thing is do we have any test code to test our driver thoroughly?
Regards
> Pterm Utility
> Hi Derek,
> Regards,
> Pterm
> > Utility
> > getting this error
> with
> > the format.
> > resolution).
> on
> process"
> > and
> > Regards,
> > Advanced Graphics
> Advanced Graphics
RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Just got that stuff working today. I slayed the Photon app and then run
panel.
QNX display driver.
everything with my display driver ,i.e, draw images, run 2D/3D demo
DL:  Yes, you cannot run img_decode_simple (GF application) on the same
layer that Photon is working, glad you figured it out OK.
buffer. Is it the one in build file, the parameters we pass to the start
thoroughly?
DL:  Do you have a video decoder on your board?  Does it present to a
physical address?  frame buffer is just a region of memory.
Regards
> Pterm Utility
> Hi Derek,
> Regards,
> Pterm
> > Utility
the
jpg/bmp
> > getting this error
> with
> > the format.
> > resolution).
anything
> on
> process"
> > and
> > Regards,
> > Advanced Graphics
> Advanced Graphics
Advanced...
Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Thanks for the reply Derek. I did the porting of display driver in WindowsCE 6.0 as well. As per the TRM we could
allocate a region of physical memory from SRAM/SDRAM and I just mapped the SDRAM area for the frame buffer. I am not
aware of any video decoder in omap2430.
From all the discussions/forum I know that Frame buffer is a memory region which must be continuous. But just couldn't
relate this with my devg code or build file.
As per Armin he says we need to include SDL libraries which takes care of the frame buffer in QNX but I have not seen
any reference of it in my bsp.
> panel.
> QNX display driver.
> thoroughly?
> Regards
> > Pterm Utility
> > Hi Derek,
> > Regards,
> > Pterm
> > > Utility
> the
> jpg/bmp
> > > getting this error
> > with
> > > the format.
> > > resolution).
> > > regarding the hybrid apps that you shared, I am not able...
RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
I still do not understand what you are trying to accomplish ...
You talk of a "frame buffer" ... do you mean the actual display memory
for the layer, or something else?  If you are already displaying
application, GF and Photon, then you are using the "frame buffer".
If not, what will you use this "frame buffer" for?
Sent: February 14, 2011 12:43 PM
Subject: Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging
after Pterm Utility
WindowsCE 6.0 as well. As per the TRM we could allocate a region of
frame buffer. I am not aware of any video decoder in omap2430.
region which must be continuous. But just couldn't relate this with my
of the frame buffer in QNX but I have not seen any reference of it in my
bsp.
run
> panel.
> QNX display driver.
same
start
> thoroughly?
> Regards
after
> > Pterm Utility
> > Hi Derek,
> > Regards,
> > Pterm
> > > Utility
procedures
> the
> jpg/bmp
> > > photon/io-display/io-graphics...
Re: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: RE: Display Hanging after Pterm Utility
Let me just re-phrase my question again, Derek.
I know that the frame buffer is a physical memory which we use as a display memory to render the display images.
My question is ..."which part of the devg-driver code does this? any particular api?"
I hope I have made myself clear.
> after Pterm Utility
> bsp.
> Regards,
> run
> > panel.
> > QNX display driver.
> same
> start
> > thoroughly?
> > Regards
> after
> > > Pterm Utility
> > > Hi Derek,
> > > Regards,
> > > > Subject: Re: RE: RE: RE: RE:...
