Forum Topic - How to display an image.:
Since sample code or tutorials are not available, I'll try a more specific question.
I'm trying to display a BMP file.  The file format is IMG_FMT_PAL1.  My layer format is GF_FORMAT_BGR888.  My call to
gf_surface_attach is failing with GF_ERR_PARM.  I'm guessing (because its not documented) that I need to convert the
image before trying to attach it.  I have found the img_dtransform* and img_convert* functions, but there are no
examples on how or when to use them.  I'm also reading conflicting information on which functions support pallet-based
images.  How do I display a BMP file?  I am using 6.5.0
P.S. These functions should be called Primitive Graphics instead of Advanced Graphics, because I am writing an awful lot
 of code to do simple things.
RE: How to display an image.
What about gf_draw_bitmap()?
From: Robert Murrell [mailto:community-noreply@qnx.com]
Sent: November 8, 2010 11:14 AM
To: advanced-graphics
Subject: How to display an image.
specific question.
layer format is GF_FORMAT_BGR888.  My call to gf_surface_attach is
that I need to convert the image before trying to attach it.  I have
information on which functions support pallet-based images.  How do I
Advanced Graphics, because I am writing an awful lot of code to do
simple things.
Advanced Graphics
http://community.qnx.com/sf/go/post73863
Re: RE: How to display an image.
I have that working for the IMG_FMT_PAL1 in a legacy function.  But I want to make a generic function that will take BMP
, GIF, JPG, and PNG images passed by file name and display them.  BMP files have several pallet sizes that will not work
 for gf_draw_bitmap.  How do I do this?
RE: RE: How to display an image.
Do you mean GIF files have several palette sizes?
Sent: November 8, 2010 11:30 AM
Subject: Re: RE: How to display an image.
want to make a generic function that will take BMP, GIF, JPG, and PNG
pallet sizes that will not work for gf_draw_bitmap.  How do I do this?
Advanced Graphics
http://community.qnx.com/sf/go/post73874
Re: RE: RE: How to display an image.
No.  BMP files come in IMG_FMT_PAL1, IMG_FMT_PAL4, and IMG_FMT_PAL8 flavors.  As I remember, GIF files are only
IMG_FMT_PAL8.
RE: RE: RE: How to display an image.
I stand corrected.
Sent: November 8, 2010 12:11 PM
Subject: Re: RE: RE: How to display an image.
flavors.  As I remember, GIF files are only IMG_FMT_PAL8.
Advanced Graphics
http://community.qnx.com/sf/go/post73896
Also please post your code snippet using gf_surface_attach().
Advanced Graphics
This code is basically the sample code snippets from the Users Guide strung together with some guesses added to get it
to compile.
void DRAW::DrawImg(char *fname)
	int stats;
	img_lib_t ilib = NULL;
	img_t img;
	gf_palette_t palette;
	gf_surface_t img_surf;
	img.flags = 0;
	if ((stats = img_lib_attach(&ilib)) == IMG_ERR_OK) {
		stats = img_load_file(ilib, fname, NULL, &img);
		img_lib_detach(ilib);
		if (img.format & IMG_FMT_PALETTE) {
			/* setup palette if necessary */
			palette.ncolors = img.npalette;
			palette.colors = img.palette;
		} else if (img.format == IMG_FMT_G8) {
			/* we can render G8 images in GF by using a palette of grays */
			palette.ncolors = 256;
			palette.colors = (img_color_t*)g8pal;
		if ((stats = gf_surface_attach(&img_surf, gdev,
		        img.w, img.h, img.access.direct.stride, (gf_format_t)img.format,
		        &palette, img.access.direct.data, 0)) == GF_ERR_OK) {
			if (img.flags & IMG_TRANSPARENCY) {
			        /* we can handle transparency in GF using chroma */
				gf_chroma_t        chroma;
				memset(&chroma, 0, sizeof chroma);
				chroma.mode = GF_CHROMA_OP_SRC_MATCH | GF_CHROMA_OP_NO_DRAW;
						chroma.color0 = img.palette[img.transparency.index];
				} else if (IMG_FMT_BPP(img.format) < 24) {
						chroma.color0 = img.transparency.rgb16;
				} else {
						chroma.color0 = img.transparency.rgb32;
				gf_context_set_chroma(context, &chroma);
			if (img.format & IMG_FMT_ALPHA) {
				gf_alpha_t        alpha;
				memset(&alpha, 0, sizeof alpha);
				alpha.mode = GF_ALPHA_M1_SRC_PIXEL_ALPHA | GF_BLEND_SRC_M1 |
					GF_BLEND_DST_1mM1;
				gf_context_set_alpha(context, &alpha);
			stats = gf_draw_begin( context );
			//render image on a surface
			gf_draw_blit2(context, img_surf, NULL,
					0, 0, img.w - 1, img.h - 1, Pen.X, Pen.Y);
			gf_draw_finish(context);
			/* unlock the h/w */
			gf_draw_end(context);
			        gf_context_disable_alpha(context);
			        gf_context_disable_chroma(context);
			/* release the attached surface; we're not going to blit from it any
			   more (in real life this surface could be recycled if needed) */
			gf_surface_free(img_surf);
			free(img.access.direct.data);
	if (stats) {
		printf("Image error: %d\n", stats);//debug
Ok, I think I know the issue, the is not GF_FORMAT_PAL1, only PAL8, so
the call errors out.
My best suggestion would be to force the output format in the img_t
before call img_load_file().
img.format = IMG_FMT_BGRA8888;
img.flags |= IMG_FORMAT;
See it that makes it work better ...
Sent: November 8, 2010 12:16 PM
strung together with some guesses added to get it to compile.
	int stats;
	img_t img;
	img.flags = 0;
palette of grays */
GF_ERR_OK) {
using chroma */
				gf_chroma_t        chroma;
						chroma.color0 =
						chroma.color0 =
				} else {
						chroma.color0 =
				gf_alpha_t        alpha;
| GF_BLEND_SRC_M1 |
					GF_BLEND_DST_1mM1;
Pen.X, Pen.Y);
to blit from it any
	if (stats) {
Advanced Graphics
http://community.qnx.com/sf/go/post73898
Re: RE: RE: RE: How to display an image.
I still get the same error.  For your reference, I have attached the actual BMP file that I am trying to load.
Attachment: Bitmap walpaper.bmp 414 bytes
