Forum Topic - blend_pixels:
blend_pixels
Hi, All
When I read the ddk , I am little confused by the comments.
void (*blend_pixels)(
        disp_draw_context_t *ctx,
        int x[],
        int y[],
        uint8_t alpha[],
        int npixels );
Pixels are drawn at the coordinates specified by the x and y arrays, using the corresponding values in the alpha array
as coverage values. The coverage values specify the intensity of the pixel (0xFF is full intensity, 0x00 is no
intensity) when it is finally written to the destination. If alpha blending is enabled, the coverage value is moderated
with the source alpha value. Otherwise, the final pixel value is written to the destination with the following blend
operation:
Pdst - (Pv × coverage) + Pdst × (1 - coverage)
Pdst is from the dst surface.
But What is Pv from?
There is no parameters in functions, and no obvious member in context.
Thanks!
Ivan
RE: blend_pixels
Hi Ivan,
FYI, there are two, you are looking at the context blend function, but the core blend function is defined as:
void (*blend_pixels)(disp_draw_context_t *ctx, disp_color_t color,
	int x[], int y[], uint8_t alpha[], int npixels);
Anyways, in the context blend function, you obtain the source pixel value (Pv) for the foreground colour:
ctx->fgcolor
-Derek
Sent: Wednesday, July 14, 2010 12:32 AM
To: advanced-graphics
Subject: blend_pixels
Hi, All
        int x[],
        int y[],
        uint8_t alpha[],
        int npixels );
operation:
Thanks!
Ivan
Advanced Graphics
http://community.qnx.com/sf/go/post59373
Re: RE: blend_pixels
Derek:
Thanks for your reply! I understand it.
Best regards
Ivan
