08/03/2009 10:13 AM
post35137
I have created "holder" for filesystem in file with:
dd if=/dev/zero of=/file.dat count=10000
mkqnx6fs /file.dat
mount -tqnx6 /file.dat /qq
So far, do good. I can work with file system as required.
Afterwards I umount /qq, move /file.dat to a "FAT16" filesystem and try to remount it:
umount /qq
mv /file.dat /dev/dos/file.dat
mount -tqnx6 /dev/dos/file.dat /qq
And it fails with "Block device required"
If I try to mount it read only, it works.
Are there any options to make it work read/write also on FAT filesystem?
devb-eide is started with qnx6 sync=optional, but the behaviour is the same, even when I start devb-eide with qnx6 sync=
ignore
Thanks, PKY
08/04/2009 10:09 AM
post35176
Pavol Kycina wrote:
> Hello,
> mkqnx6fs /file.dat
> umount /qq
ENODEV indicates a mismatch in sector size would violate the ability of
the fsys to perform atomic/powersafe updates, thus it allows read-only.
Your mkqnx6fs will have made 1k blocks, your FAT is likely 4k clusters
(or some number >1k). Thus it is not possible to write to a single
block of the fsys when hosted on an image that way without also writing
to other fsq6 blocks residing within the same FAT host block, which
violates the fsq6 "no-overwrite live data" principle.
The host sector size must be less than or equal to the fsys block size;
it is allowed to have to write multiple blocks to make up one fsys
write, but invalid to have one host write touch multiple fsys blocks.
Do a "df -g" of your FAT and see what cluster size it used, and if 2k/4k
then you can reformat the fsq6 (mkqnx6fs -bXX) to match and then it will
mount r/w. Otherwise is >4k then this is not possible to do (without
reformating your FAT 'mkdosfs -cXX'; note that generally FAT32 is 4k
clusters, which would work).
08/04/2009 10:17 AM
post35178
Thanks a lot.
It works now!
PKY
> Pavol Kycina wrote:
> > Hello,
> > mkqnx6fs /file.dat
> remount it:
> > umount /qq
08/21/2009 7:12 AM
post36406
Hello again.
Now I have CF which has 8kB blocks.
Any chance that mkqnx6fs will support blocks larger than 4kB?
Thanks, PKY
> Thanks a lot.
> It works now!
> PKY
> > Pavol Kycina wrote:
> > > Hello,
> > > mkqnx6fs /file.dat
> > remount it:
> > > umount /qq
08/21/2009 9:53 AM
post36416
Pavol,
Not at the moment. 4k is the maximum block size for fsqnx6. Are you
able to re-format the FAT filesystem to use 4k clusters?
David
> From: Pavol Kycina [mailto:community-noreply@qnx.com]
> Sent: August 21, 2009 7:12 AM
> To: general-filesystems
> Subject: Re: QNX6FS in file
> Hello again.
> Thanks, PKY
> > Thanks a lot.
> > It works now!
> > PKY
> > > Pavol Kycina wrote:
> > > > Hello,
> > > > dd if=/dev/zero of=/file.dat count=10000 mkqnx6fs
> /file.dat mount
> > > > and try to
> > > remount it:
> > > > umount /qq
> > > > mount -tqnx6 /dev/dos/file.dat /qq And it fails with
> "Block device
> > > > required"
> on FAT filesystem?
> the ability
> > > of the fsys to perform atomic/powersafe updates, thus it
> allows read-only.
> > > clusters (or some number >1k). Thus it is not possible
> to write to
> > > a single block of the fsys when hosted on an image that
> way without
> > > also writing to other fsq6 blocks residing within the
> same FAT host
> > > block, which violates the fsq6 "no-overwrite live data" principle.
> > > size; it is allowed to have to write multiple blocks to
> make up one
> > > fsys write, but invalid to have one host write touch
> used, and if
> > > 2k/4k then you can reformat the fsq6 (mkqnx6fs -bXX) to match and
> > > then it will mount r/w. Otherwise is >4k then this is
> not possible
> > > to do (without reformating your FAT 'mkdosfs -cXX'; note that
> > > generally FAT32 is 4k clusters, which would work).
> http://community.qnx.com/sf/go/post36406
08/21/2009 4:03 PM
post36454
> Pavol,
> David
[snip]
Not without changing the way we treat CF card. We should use 512MB ones, with FAT16 it means 8k clusters.
Either we change the system to FAT32, that would mean making new custom loader (the present one is bound to FAT16. Or we
introduce partition table to CF (now we treat it as a very large floppy) and that would mean changes in custom CF
formatter.
FAT32 option seems more reasonable now, but it's Friday late evening ;-)
Regards, PKY
