Re: SD card writes don't commit
07/25/2009 11:41 AM
post34584
> I'm working on an SD driver as I write this.
> My suspicion is that your driver is not actually carrying out the transaction
> to write to the SD card correctly, but yet is telling io-blk that it has w/o
> error....so io-blk carries on as if nothing is wrong.
> You'll need to actually see the blocks being written, I would instrument your
> driver to see that the correct steps are taken and that you are getting a
> Transfer Complete interrupt (if your controller supports it) after the
> WRITE_SINGLE or WRITE_MULTIPLE block completes.
Did this and see the writes happening. I have a loop to retry if data error occurs (happens now and then). I was using
stream mode for some odd reason and changed to block mode. Now it seems to be working correctly, files are present after
slaying the driver and restarting/remounting.
> When you run your driver try the following to get rid of cache:
> devb-sd blk cache=0 <other parameters>
figured this out yesterday. 0 gave me very slow response and some funny looking garbage at the end of files. changed to
128k and things look better.
> There are other io-blk parameters that may be helpful, see the io-blk.so entry
> in the Utilities Reference.
> Kevin
Thanks Kevin!!! You've been a great amount of help.
Todd
