Forum Topic - NAND ETFS -C2 option: (3 Items)
We have implemented the ETFS on 2k NAND flash. It seems to work OK using the command line of etfs -r 12800 -C0 -e
(reserve 12800 kB for boot image, no error checking, erase & format), but if -C2 is used (full error checking), we get
the message 'etfs: No filesystem detected. Entering stopped mode.' Doing a ls of /fs/etfs gives error of 'ls: Resource
busy (/fs/etfs)'
Have tried using etfsctl -c to resume and get 'Error status on option 'c' : Corrupted file system detected'
Tried: etfsctl -d /dev/etfs2 -f, and get no error message, but ls still does not work.
Am I doing something wrong? Or missing something?
RE: NAND ETFS -C2 option
Todd,
Just to be clear, when you change from -C0 to -C2, you are erasing and
formatting the filesystem again?
David
> From: Todd Peterson [mailto:community-noreply@qnx.com]
> Sent: July 8, 2009 10:29 AM
> To: general-filesystems
> Subject: NAND ETFS -C2 option
 the
> busy (/fs/etfs)'
> http://community.qnx.com/sf/go/post33396
Re: RE: NAND ETFS -C2 option
yes, I use the command:
etfs -r 12800 -C2 -e
which should erase and format. i've attached a file of what the 1st sector of the 1st 2 blocks to be erased/formatted
(0x1900 & 0x1940) after the command completes.
Todd
Attachment: Text sector0x1900.txt 12.67 KB
