Forum Topic - etfs transactions during write : (5 Items)
if I produce a new file with .e.g. "dd if=/dev/zero of=writefile &", and switch of the power.
I get following after power on again:
fs-etfs-mpc5121: Truncating fid 0x2b3 from 958275584 to 0 bytes
It looks like the etfs Filesystem truncates the file to the size, at which the file was closed last. If case of a new
file the last secure size seems to be 0.
If you create a logfile with write() , you can loose gigabytes of data, if power fails.
Should I insert  close() and open() or some fsync() from time to time?
This problem does not occur with fs-qnx6. Her you only loose some blocks in case of powerfail.
What do I miss here?
Kind regards
Michael
Re: etfs transactions during write
Ping.
> switch off the power.
>  file was closed last. If case of a new file the last secure size seems to be
> 0.
> power fails.
> This problem does not occur with fs-qnx6. Here you only loose some blocks in
> case of powerfail.
> Kind regards
> Michael
>>0.
Yes, in a conflict betwen the file size and replay transactions, the
last size is used and excess data transactions are discarded.
To save NAND wear the inode entry (in the .filetable) is by default not
updated in tandem with the file data.  The trigger points are either
last close(), an explict fsync(), global sync(), or by using O_SYNC (but
beware the potential for flash lifetime/wear with the later approach).
>>power fails.
If nothing updated the file size, correct.  This is why, for eg, slogger
gained a '-c' option!
Yes, either, as above.  Arranging a periodic fsync is probably most
efficient.  You could peridically "sync" as well (requiring no internal
code changes) but of course this will hit all mounted filesystems, so
may not be appropriate.
>>case of powerfail.
A major difference is that fs-qnx6 will periodically commit itself
('qnx6 snapshot=' period), in addition to allowing explicit user fsync()
or sync().  So the file size will be exactly consistent with the data
written at that point in time.  Other disk filesystems always schedule
an inode update in conjunction with data writes but use the delayed
write-behind ('blk delwri=') period, since contrasted to flash the issue
is one of performance rather than media wear; but they can't make the
same strong guarantees that fs-qnx6 does with regards to consistency
between file size and data content (one of the inode or new data must
hit the disk first).
ETFS ordering the data write before the inode combined with the
fid/transaction discard means the data should be consistent up to the
advertised size, but requires some application help to trigger the inode
write (in the absence of an internal periodic sync) to allow the file
size to advance.  In most cases said file eventually gets closed; the
logfile example is an obvious exception.
Hello John,
thank you very much for clarifying this to me.
I wanted to be sure, that my flash-driver is really ok.
Our customner is producing increasing protcoll files in a 1GB-Nand-Flash.
So he should use fsync() from time to time.
But our customner found annother problem:
After  editing an old  text file on the target via eclipse/qconn connection, the text-file can result in a zero length
file ("fs-etfs-mpc5121: Truncating fid ... from ...to 0" ), if power is switched off > 5min "after" the file has been
saved via eclipse.
At the moment I hope this is a problem with the eclipse/qconn/target-filesystem access...
Kind Regards
Michael
> >>0.
> >>power fails.
> >>case of powerfail.
> can't make the
saved via eclipse.
IIRC, this is a known/related issue; the IDE keeps the fd to the edit
file open, and so the last-close-filetable-update never gets to happen.
