Need help initializing filesystem.
06/11/2009 12:03 PM
post31502
I have looked over code for flashctl, etfsctl, and fs-etfs-nand and I do not know where to go from here. I am new to
this flash filesystem stuff. I know in Linux a normal storage device shows up in /dev as dev-n where dev is device
specific and n is partition. When I run fs-etfs-nand I get /fs/etfs and /dev/etfsn (n=1,2). I know I am seeing the
device as etfsctl returns;
# ./etfsctl -i
Device NAND2caa
Blocks Clusters/Block Clustersize Totalsize
2048 64 2048 268435456
Pools
Clean Spare Filthy Inactive Xpool Cache
0 0 1995 127680 2048 64
Counts
Erase Avg Read Cache Write Mine Copy Defrag BadBlks
0 0 0 0 0 0 0 0 53
Errors
Ecc Chksum Device
0 0 0
Which is correct.
To summarize the hardware, I have LPC3180 with MT29F2G08AAD NAND Flash. The bootable image resides in flash from block
0 through block 100. I want to use all the blocks after 100 for a filesystem.
Can anyone give me directions as to where I need to look? etfsctl seems to recognize the hardware, but does not have
the ability to create custom partitions. flashctl has the ability to create custom partitions, but does not recognize
the hardware (is not getting correct information back from device).
RE: Need help initializing filesystem.
06/11/2009 12:27 PM
post31506
Durwin,
Since you are using NAND flash, fs-etfs-nand is the right driver for you
to use. Etfsctl is the proper command-line utility: flashctl is the
command-line util for the devf-* series of drivers, which use a
different filesystem, and target NOR flash.
The ETFS filesystems only support two partitions: a raw partition, and a
formatted partition. The raw partition is always called /dev/etfs1, and
the formatted partition is called /dev/etfs2. By default the raw
partition is zero sized, and the formatted partition fills the entire
NAND part.
Since you have /fs/etfs, that means that /dev/etfs2 is properly
formatted, and mounted. /fs/etfs is the filesystem mountpoint.
To set the size of the raw partition (/dev/etfs1), use the "-r" option
to fs-etfs-nand. This option takes as an argument the number of
Kilobytes to reserve. This number needs to be a multiple of the block
size of the NAND hardware (128kB in your case). /dev/etfs1 will then be
accessible as a physically contiguous portion of NAND flash, to which a
boot image, or other files, can be written. The raw partition does not
silently skip bad blocks, and does not perform wear-levelling (as it has
no idea what the format of the contained data is).
David
> From: Durwin De La Rue [mailto:community-noreply@qnx.com]
> Sent: June 11, 2009 12:04 PM
> To: general-filesystems
> Subject: Need help initializing filesystem.
> new to this flash filesystem stuff. I know in Linux a normal
> # ./etfsctl -i
> Device NAND2caa
> Pools
> Counts
> Defrag BadBlks
> 0 0 0 0 0 0 0
> 0 53
> Errors
> Ecc Chksum Device
> 0 0 0
> Which is correct.
> NAND Flash. The bootable image resides in flash from block 0
> for a filesystem.
> http://community.qnx.com/sf/go/post31502
Re: RE: Need help initializing filesystem.
06/11/2009 1:29 PM
post31528
Thank you for your reply.
> Durwin,
> NAND part.
I have tried to 'cd' into /fs/etfs and received message 'device busy'. I get same message trying to perform other tasks
on it.
Normally I would try to mount /dev/etfs2 as the partition I want to a mount point. But even doing this fails giving;
mount: Can't mount /mnt/usb (type qnx4)
mount: Possible reason: No such device or address
Do I need to format it?
Do I specify the size of etfs1 (raw partition) to include the 0-100 blocks I need reserved?
> David
> > # ./etfsctl -i
> > Device NAND2caa
> > Pools
> > Counts
> > Defrag BadBlks
> > 0 0 0 0 0 0 0
> > 0 53
> > Errors
> > Ecc Chksum Device
> > 0 0 0
> > Which is correct.
> > for a filesystem.
RE: RE: Need help initializing filesystem.
06/11/2009 1:41 PM
post31530
> Sent: June 11, 2009 1:29 PM
> Subject: Re: RE: Need help initializing filesystem.
> > Durwin,
> driver for
> > you to use. Etfsctl is the proper command-line utility:
> flashctl is
> > the command-line util for the devf-* series of drivers, which use a
> partition, and
> > a formatted partition. The raw partition is always called
> /dev/etfs1,
> > and the formatted partition is called /dev/etfs2. By
> default the raw
> the entire
> > NAND part.
> tasks on it.
That means the filesystem is in the stopped state. ETFS has the notion
of "stopped" filesystem (similar to pausing). The filesystem will be in
this state if it's not formatted. If this driver is pre-6.4.0, then
that makes sense, as ETFS will auto-create the /fs/etfs mountpoint
whether it's formatted or not.
You'll nave to do "etfsctl -d /dev/etfs2 -efc" to erase, format, and
then "continue" the stopped filesystem. At that point, you'll be able
to access /fs/etfs.
Yes, just like above.
Also, if you want to mount it you'll have to do:
mount -t etfs /dev/etfs2 <mountpoint>
Otherwise you get that error about it not being an fs-qnx4 filesystem.
> "-r" option
> of the block
> will then
> > be accessible as a physically contiguous portion of NAND flash, to
> > which a boot image, or other files, can be written. The
> raw partition
> > does not silently skip bad blocks, and does not perform
> wear-levelling
> > (as it has no idea what the format of the contained data is).
Because NAND can have bad blocks, I would specify more than the 100
blocks.
Eg. Blocksize = 128k
128k * 105 blocks = 13440kB
fs-etfs-nand -r 13440 -m /fs/etfs -D<opts>
If you want it auto-erased and formatted, also specify -e.
> > David
> fs-etfs-nand and
> > > I do not know where to go from here. I am new to this flash
> device shows up
> > > in /dev as dev-n where dev is device...
Re: RE: RE: Need help initializing filesystem.
06/11/2009 3:21 PM
post31541
This was sounding so positive. I run;
fs-etfs-nand -r 12800 -m /fs/etfs
This is where I now have trouble. It says;
Error status on option 'c' : Corrupted file system detected
If I do not use '-c', it returns status=0 and it takes a few seconds to do what it is doing. But then if I '-c', it
returns same error. Unless I am over looking something, I guess I need to dive into the driver code.
> > > Durwin,
> > driver for
> > flashctl is
> > partition, and
> > /dev/etfs1,
> > default the raw
> > the entire
> > > NAND part.
> > tasks on it.
> to access /fs/etfs.
> > "-r" option
> > of the block
> > will then
> > raw partition
> > wear-levelling
> Because NAND can have bad...
RE: RE: RE: Need help initializing filesystem.
06/11/2009 3:39 PM
post31546
Durwin,
I've made a small error. The -ef is redudant. -e means "erase all the
blocks". -f mean "erase the blocks and format". So please specify only
-f to etfsctl.
The -c is giving you the error because that's what triggers ETFS to
actually start scanning the filesystem and checking for consistency.
Please re-do the test without the -e on etfsctl, and please add -vvv to
the commandline of fs-etfs-nand.
David
> Sent: June 11, 2009 3:21 PM
> Subject: Re: RE: RE: Need help initializing filesystem.
> > > > Durwin,
> > > driver for
> > > flashctl is
> which use
> > > > a different filesystem, and target NOR flash.
> > > partition, and
> > > /dev/etfs1,
> > > default the raw
> > > the entire
> > > > NAND part.
> > > busy'. I get same message trying to perform other tasks on it.
> > notion of "stopped" filesystem (similar to pausing). The
> filesystem
> > will be in this state if it's not formatted. If this driver is
> > pre-6.4.0, then that makes sense, as ETFS will auto-create the
> > /fs/etfs mountpoint whether it's formatted or not.
> format, and
> you'll be able
> > to access /fs/etfs.
> I want to
> > mount -t etfs...
Re: RE: RE: RE: Need help initializing filesystem.
06/11/2009 3:50 PM
post31549
I actually did try without -e (had looked at the usage text), but I repeated with -vvv and got not one extra bit of
information. Do I need to recompile it with an option to get debugging info?
# etfsctl -d /dev/etfs2 -fc -vvv
Process 61456 (D:\QNX632\workspaceActive\os-efsys_efsys\utils\e\etfsctl\nto\arm-le\etfsctl) exited status=1.
> Durwin,
> -f to etfsctl.
> David
> > > > > Durwin,
> > > > driver for
> > > > flashctl is
> > which use
> > > > partition, and
> > > > /dev/etfs1,
> > > > default the raw
> > > > the entire
> > > > > NAND part.
> > filesystem
> > > /fs/etfs mountpoint whether it's...
