Forum Topic - NAND flash support for 5 addr cycles?: (4 Items)
Looking at nand.c, it is not obvious that 5 address cycles are supported. I
did not find the code for the low-level functions such as nandio_init1,
nandio_reset, nandio_idread, etc. Am I missing something? Is there a good
sample for building a complete resource manager using a large-block NAND
flash. Our mfr. code is 0xEC, and type 0xAA. Added a section to nand_init:
      case 0xaa:  // 128 Mbyte
            ncp->numblks     = 2048;
            ncp->addrcycles  = 5;
            ncp->pagemapbits = 18;
            ncp->totspares   = 40;
            break;
The controller (NXP LPC3180-01) has two NAND controllers to select from, a
single-level and multi-level. I can use raw C code (no OS) to do basic
operations on these 2 controllers (get id, read, erase, write). Just am a
bit confused how to use nand.c properly.
RE: NAND flash support for 5 addr cycles?
Todd,
The code for the low-level functions are packaged with the specific BSP
downloads.  The devio.c provides functions for interfacing with the NAND
controller on your particular board.
As an example, take a look at the MPC5121 BSP, which has low-level code
for 2k-page NAND.  The specifics will probalby have to change for your
controller, but this shows the overall layout of the code.  This code
uses 5 address cycles.
http://community.qnx.com/sf/wiki/do/viewPage/projects.bsp/wiki/Freescale
Mpc5121eAds
David
> From: Todd Peterson [mailto:community-noreply@qnx.com]
> Sent: March 9, 2009 11:01 PM
> To: general-filesystems
> Subject: NAND flash support for 5 addr cycles?
> are supported. I did not find the code for the low-level
> functions such as nandio_init1, nandio_reset, nandio_idread,
> etc. Am I missing something? Is there a good sample for
> to nand_init:
>             break;
> select from, a single-level and multi-level. I can use raw C
> code (no OS) to do basic operations on these 2 controllers
> (get id, read, erase, write). Just am a bit confused how to
> http://community.qnx.com/sf/go/post23988
Re: RE: NAND flash support for 5 addr cycles?
OK, so I modified the freescale code to talk to my NAND. It complains with "Unsupported NAND device (2c aa 80 15). I
tried first with endian swapping in READID function and get "Unsupported NAND device (15 80 aa 2c)".
What are the supported types? How do I add mine?
never mind...I think I've got it.
