Forum Topic - hd0t12: (4 Items)
hd0t12
I have a QNX and I have created a second partition (FAT32).
I want a second partition to run Windows XP.
With the commands:
fdisk /dev/hd0 add -b -t 12 -p 50
mount -e /dev/hd0
dinit -h /dev/hd0t12
mount /dev/hd0t12 /
With theses commands, the hard disk seems to have the partition that I need. I took a look on that with the command:
fdisk /dev/hd0 show
fdisk /dev/hd0t12 show
But, when I reboot the machine and try to boot on the partition 2, after the lines
"Pres ESC to .alboot...................................................................................................
nothing happen.
When I boot on the partition 1, the machine boot but is not able to mount the fs-dos.so on hd0t12(corrupted system
file detected).
I have already use the chkfsys command to verify the file.
What can I do to repair the file? Or what I did wrong?
Thank's
________________________
C. Bouchard
RE: hd0t12
> From: Catherine Bouchard [mailto:community-noreply@qnx.com]
> Sent: March-02-09 4:32 PM
> To: general-filesystems
> Subject: hd0t12
> With the commands:
> mount -e /dev/hd0
Can't do that because dinit create a QNX filesystem, yet it's a FAT32 partition.  Windows wouldn't be able to access it.
> mount /dev/hd0t12 /
> fdisk /dev/hd0 show
> after the lines
You would need to put a valid .boot file on that partition, but it's a FAT32 filesystem, although I guess it's doable
you can't really expect QNX to boot from it.
> "Pres ESC to
> nothing happen.
> to mount the fs-dos.so on hd0t12(corrupted system file detected).
QNX detected the type and assume it's FAT32 but you formatted it ( dinit) with a  QNX filesystem. That doesn't compute
Chkfsys works for QNX filesystem.
The file is not damaged
You assumed partition type is all that was need to make it compatible but forgot about the importance of the filesystem.
> Thank's
> C. Bouchard
> http://community.qnx.com/sf/go/post23281
RE: hd0t12
> Sent: March 2, 2009 4:32 PM
> Subject: hd0t12
> With the commands:
> mount -e /dev/hd0
Since you want a FAT32 filesystem, in order to run Windows, the next line should be
mkdosfs -F32 /dev/hd0t12
Which will give you a FAT32 filesystem in the new type 12 partition.
> fdisk /dev/hd0 show
The partition type is right, but the contents of the partition are QNX4 file system(if you use the dinit program).
Using mkdosfs, you'll get the FAT32 that you expect.
> partition 2, after the lines "Pres ESC to
> nothing happen.
> able to mount the fs-dos.so on hd0t12(corrupted system file detected).
> Thank's
> C. Bouchard
Re: RE: hd0t12
Thank you for the informations, I understand more now!
