08/08/2008 5:04 PM
post11599
> I am trying to build latest trunk, here is the error.
> (I have properly set the QCONF_OVERRIDE)
> /bin/rm -f /qnx/src/fs/services/cifs/sh/le/fs-cifs
> /qnx/qnx632/host/linux/x86/usr/bin/qcc -V4.2.3,gcc_ntosh -Wl,--no-keep-memory
> -o/qnx/src/fs/services/cifs/sh/le/fs-cifs CIFS_NOSYS.o buf.o
> chap_ms.o cifs_mount.o crc32.o inode.o io_attr.o io_close.o
> io_devctl.o io_mknod.o io_mmap.o io_mount.o io_open.o io_openfd
> .o io_pathconf.o io_read.o io_rename.o io_seek.o io_space.o
> io_stat.o io_unblock.o io_unlink.o io_utime.o io_write.o
> iofunc_ocb.o main.o md4c.o misc.o options.o smb_chkdir.o
> smb_close.o smb_closedir.o smb_connection.o smb_mkdir.o smb_open.o
> smb_read.o smb_readdir.o smb_rename.o smb_rmdir.o smb_send.o
> smb_stat.o smb_stat2.o smb_stat3.o smb_statfs.o smb_times.o
> smb_unlink.o smb_write.o smbnt_getattr.o smbnt_open.o smbnt_read.o
> smbnt_seek.o smbnt_setattr.o smbnt_write.o -L. -L/qnx/build/stage/
> shle/lib/gcc/4.2.3 -L/qnx/build/stage/shle/lib -L/qnx/build/stage/shle/usr/lib
> -L/qnx/qnx632/target/qnx6/shle/lib/gcc/4.2.3 -L/qnx/qnx632/target/qnx6/shle/
> lib -L/qnx/qnx632/target/qnx6/shle/usr/lib -lsocket -ldes -EL
> chap_ms.o: In function `DesEncrypt':
> chap_ms.c:(.text+0x118): undefined reference to `des_set_odd_parity'
> chap_ms.c:(.text+0x11c): undefined reference to `des_set_key'
> chap_ms.c:(.text+0x120): undefined reference to `des_ecb_encrypt'
> cc: /qnx/qnx632/host/linux/x86/usr/bin/ntosh-ld-2.18 error 1
> make[4]: *** [/qnx/src/fs/services/cifs/sh/le/fs-cifs] Error 1
> make[4]: Leaving directory `/qnx/src/fs/services/cifs/sh/le'
> make[3]: *** [all] Error 2
> make[3]: Leaving directory `/qnx/src/fs/services/cifs/sh'
> make[2]: *** [all] Error 2
> make[2]: Leaving directory `/qnx/src/fs/services/cifs'
> make[1]: *** [all] Error 2
> make[1]: Leaving directory `/qnx/src/fs/services'
> make: *** [all] Error 2
> make: Leaving directory `/qnx/src/fs'
It built for me here, after building and installing libdes.a to the staging area. You're staging area looks to be setup
correctly, according to the command-line. Is libdes.a present in /shle/lib within your staging area?
David
