Forum Topic - want to flash something: (3 Items)
:-) David,
How can I find out the correct seek and bs values for dd so that I can flash a bootable ifs and (directly ? )after that
a non bootable efs ?
And if You see this:
slay devf-generic
devf-generic -s0x20000000,128M
waitfor /dev/fs0
flashctl -p /dev/fs0 -o 256k -l 49M -e -vvv
dd if=someboot.bin of=/dev/fs0 seek=256 bs=1024
dd if=/exec/someefs.efs of=/dev/fs0 seek=19712 bs=1024
dd if=/exec/someotherraw.efs of=/dev/fs0 seek=48384 bs=1024
Can You calculate the size in bytes of someboot.bin ?
Is someboot.bin = 19.00 MB ?
Or can it be <= 19.00 MB ?
TIA,
Jeevan
RE: want to flash something
Jeevan,
Someboot.bin has to be smaller than 19712-256 = 19456K, otherwise the
tail end will be overwritten by someefs.efs. Also, an IFS can go
anywhere (just remember that the erase you do to prepare the flash is
aligned to a sector boundary (use flashctl -p /dev/fs0 -i to see the
value), an EFS however MUST be written on a sector boundary in order for
the flash driver to detect it.
If the file someboot.bin was small, for example 3MB, devf will not tell
you that, as the first EFS starts at the 19MB offset, so /dev/fs0p0 will
be 19MB in size,regardless of how big someboot.bin actually is.
David
> From: Jeevan Mathew [mailto:jmathew@t-online.de]
> Sent: July 15, 2008 3:19 PM
> To: general-filesystems
> Subject: want to flash something
> :-) David,
> that I can flash a bootable ifs and (directly ? )after that a
> non bootable efs ?
> slay devf-generic
> waitfor /dev/fs0
> flashctl -p /dev/fs0 -o 256k -l 49M -e -vvv dd
> if=someboot.bin of=/dev/fs0 seek=256 bs=1024 dd
> if=/exec/someefs.efs of=/dev/fs0 seek=19712 bs=1024 dd
> TIA,
> Jeevan
> http://community.qnx.com/sf/go/post10562
Re: RE: want to flash something
Oh fantastic David. Thank You so much.
Jeevan
> Jeevan,
> David
> > :-) David,
> > non bootable efs ?
> > slay devf-generic
> > waitfor /dev/fs0
> > TIA,
> > Jeevan
> > General
