Forum Topic - UDF "filesystem limitation" documentation: (3 Items)
Filesystem Limitations doc page - for at least QNX7 and QNX6.6 (*)
state that for filesystem UDF, that  Soft/Symbolic Links and Hard Links are not supported.
In fact, when exercising this feature, we find that QNX's UDF implementation does support hard and soft links.  Perhaps
it was added some time ago, and they forgot to update the docs on it?
Can you update the documentation to either:
(a) reflect this support
(b) confirm that it is not supported, and state under what conditions it is not expected to work correctly.
  Brian
http://www.qnx.com/developers/docs/7.0.0/#com.qnx.doc.neutrino.sys_arch/topic/fsys_Limitations.html
http://www.qnx.com/developers/docs/6.6.0.update/#com.qnx.doc.neutrino.sys_arch/topic/fsys_Limitations.html
Re: UDF "filesystem limitation" documentation
For context:
This came up because QNX7 dropped support for the fs-cd.so driver.
We could use a loopback mounted ISO9660 w/ RR extensions as a nice readonly filesystem, containing symlinks, etc.
With fs-cd.so disappearing in QNX7, we looked at UDF, and saw that the docs said it didn't support symlinks, but in
practice they seemed implemented and worked as expected.
Thus, you could augment this request to read:
(a) bring back ISO9960 in QNX7
and/or
(b) Document that QNX's implementation of UDF (read-only, etc.) supports symlinks.
Thanks!
I checked with the developers, and fs-udf.so does support links. We'll update the docs.
