Forum Topic - Issue with USB stick under 6.6: (13 Items)
In  what may turn out to be a never ending attempt to create a bootable QNX 6.6 system using only QNX 6.6 I ran into
this roadblock.
From a QNX 6.5 VM I do the following:
# devb-umass cam pnp disk name=umass
# ls /dev/umass0
/dev/umass0  /dev/umass0t179
# mkqnx6fsys -q /dev/umass0179
# mount -tqnx6 /dev/umass0t179 /fs/usb0
When I do exactly the same thing from the QNX 6.6 VM I get the following:
#mount -tqnx6 /dev/umass0t179
mount: Can't mount /fs/usb0 (type qnx6)
mount: Possible reason: Read-only file system
Anyone run into this before?
RE: Issue with USB stick under 6.6
You need mount -t qnx6 -o sync=optional /dev/umass0t179 /fs/usb0
The USB device is not reporting that it supports the hardware sync command.
From: Mitchell Schoenbrun [mailto:community-noreply@qnx.com]
Sent: March-27-14 10:33 AM
To: general-filesystems
Subject: Issue with USB stick under 6.6
this roadblock.
# ls /dev/umass0
General
http://community.qnx.com/sf/go/post109636
To cancel your subscription to this discussion, please e-mail general-filesystems-unsubscribe@community.qnx.com
Re: RE: Issue with USB stick under 6.6
Thanks for getting back to me so fast on this.  I notice that unlike 6.5, mkqnx6fsys does not create the .boot directory
.   Will just doing a "mkdir .boot" solve that?   It seemed like there was something special about the .boot directory
that used to be created.
RE: RE: Issue with USB stick under 6.6
mkqnx6fs  should create the /.boot directory automatically.  Yes, the /.boot directory is special, and doing an "mkdir /
.boot" isn't going to work.  Do you still have the 6.5.0 version of mkqnx6fs to try, and compare (use the same OS, just
run the older binary).
Sent: March-27-14 10:41 AM
Subject: Re: RE: Issue with USB stick under 6.6
General
http://community.qnx.com/sf/go/post109638
Re: RE: RE: Issue with USB stick under 6.6
The difference appears to be "ls".
Under QNX 6.5 (and every QNX back to 4) when run as root, ls shows the DOT files.   Under 6.6 it does not.  Maybe this
is how it is supposed to work?
Yes.  ls -a will show the '.' and '..' .
> http://community.qnx.com/sf/go/post109640
Re: Issue with USB stick under 6.6
It's likely that you had an alias in your 6.5 system to add the -a to ls
No it was changed.  We were the only system that did
the dots for root and it broke stuff.
this is how it is supposed to work?
> > General
> http://community.qnx.com/sf/go/post109647
Sean,
    Now that I understand the change, it's not a problem.   But I'm very curious as what might have broke.   Anything
obvious, or all subtle stuff?
Mitchell
> Sean,
There were a couple of packages that parsed the ls output on install
and got confused.  I don't remember which ones ATM.
And yes, I'll mention this change in the release notes.
> > Sean,
> curious as what might have broke.   Anything obvious, or all subtle stuff?
At the risk of sounding Igorish, so at the risk for breaking existing customer script in favor of compatibility with
packages most of us are not able to build anymore, the behavior was changed ?
The change in behavior is not document in ls and I don`t recall reading about it anywhere.
I'm trying to hack up a way to build most things with what's
released in 6.6.
This is being addressed in a release note.  On the other hand, the
root exception was never doc'd AFAICT so it now matches its previously
doc'd behaviour.
