Forum Topic - devf-ram does not automount as described: (13 Items)
Per http://support7.qnx.com/download/download/20951/building.pdf I should be able to do the following on the Nitrogen6X
development system (using default BSP).  Assume "my_efs_img" is on the micro-SD card and I have mounted it accordingly
"mount -t dos /dev/hd0t11 /dos".
# devf-ram &
# flashctl -p /dev/fs0 -e
# cat /dos/my_efs_img > /dev/fs1
# slay devf-ram &
# devf-ram &
# cd /fs1p0
ksh: cd: /fs1p0 - No such file or directory
The last line will not work because the automount did not work properly.  Is this because there is already a flash
filesystem mounted on the Nitrogen6X board (fs0)?  I mean I should be able to mount multiple flash filesystems right?
Re: devf-ram does not automount as described
You are erasing /dev/fs0, but then writing the image to /dev/fs1. Is this what you intended?
Sent from my BlackBerry 10 smartphone.
Sent: Wednesday, May 29, 2013 3:23 PM
To: general-filesystems
Reply To: general-filesystems@community.qnx.com
Subject: devf-ram does not automount as described
development system (using default BSP). Assume "my_efs_img" is on the micro-SD card and I have mounted it accordingly "
# devf-ram &
# slay devf-ram &
# devf-ram &
# cd /fs1p0
General
http://community.qnx.com/sf/go/post101837
To cancel your subscription to this discussion, please e-mail general-filesystems-unsubscribe@community.qnx.com
Attachment: HTML sf-attachment-mime13275 3.05 KB
Sorry, that was a typo, no it is all on /dev/fs1 like so...
# devf-ram &
# flashctl -p /dev/fs1 -e
# slay devf-ram &
# devf-ram &
# cd /fs1p0
RE: devf-ram does not automount as described
> -----Message d'origine-----
> De : Erick Roane [mailto:community-noreply@qnx.com]
> Envoyé : 29 mai 2013 15:24
> À : general-filesystems
> Objet : devf-ram does not automount as described
> should be able to do the following on the Nitrogen6X development system
> mounted it accordingly  "mount -t dos /dev/hd0t11 /dos".
> # devf-ram &
> # slay devf-ram &
> # devf-ram &
> # cd /fs1p0
Maybe I`m missing something but for auto-mount to work the device has to exist. When devf-ram is killed the content  of
corresponding device, memory, is destroyed. There is nothing to auto-mount from when you restart devf-ram.
> this because there is already a flash filesystem mounted on the Nitrogen6X
> right?
Re: RE: devf-ram does not automount as described
Then why does http://support7.qnx.com/download/download/20951/building.pdf give the following guidance:
"To use the [devf-ram] flash filesystem partition, you need to slay the driver and start it again so it can recognize
the partitions and mount them. For instance, with devf-ram:
$ slay devf-ram
$ devf-ram &
From this point, you have a /fs0p1 mountpoint that’s in fact a directory and contains the files you specified with
mkefs to create your flash image."
You can substitude the "fs0p1" in the paragraph above with "fs1p0" for my Nitrogen6X system since /dev/fs0 is the on-
board boot ROM.  What other way can I mount the image using devf-ram?
RE: RE: devf-ram does not automount as described
Here's a link to the HTML version of that section:
http://www.qnx.com/developers/docs/6.5.0_sp1/topic/com.qnx.doc.neutrino_building/building_nto.html?cp=13_2_3_5_2#
TransferringToFlash
I think this section uses devf-ram as a rather artificial example to illustrate how to transfer an image to flash using
flash filesystem raw mountpoints. Perhaps we should make the example more realistic or point out that that step won't
actually work with devf-ram.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
From: Erick Roane [mailto:community-noreply@qnx.com]
Sent: Wednesday, May 29, 2013 3:36 PM
Subject: Re: RE: devf-ram does not automount as described
$ slay devf-ram
$ devf-ram &
General
http://community.qnx.com/sf/go/post101841
Re: RE: RE: devf-ram does not automount as described
Agreed, but to my other question, what other way can I transfer a pre-built image to devf-ram?  I actually want to use
it until my real flash system is available.
Copy the efs to /dev/shmem/fs0, and then start devf-ram.
Sent: Wednesday, May 29, 2013 4:42 PM
Subject: Re: RE: RE: devf-ram does not automount as described
Agreed, but to my other question, what other way can I transfer a pre-built image to devf-ram? I actually want to use it
General
http://community.qnx.com/sf/go/post101845
Attachment: HTML sf-attachment-mime13286 2.48 KB
Again, I cannot use fs0 because that is my boot ROM.  But I tried this with fs1 and this is what I got:
# cat /dos/my_efs_img > /dev/shmem/fs1
# devf-ram &
[1] 61463
[1] + Done                 devf-ram
# ls
bin     dev     dos     etc     proc    sbin    tmp     usr
# ls /dev
bpf          hd0t11       ptyp0        shmem        tap2         ttyp6
bpf0         hd0t179      ptyp1        slog         tap3         ttyp7
can0         i2c1         ptyp2        snd          text         tun0
console      i2c2         ptyp3        socket       tty          tun1
dbgmem       i2c3         ptyp4        stderr       ttyp0        tun2
fs0          io-usb       ptyp5        stdin        ttyp1        tun3
fs0p0        mem          ptyp6        stdout       ttyp2        tymem
fs1          null         ptyp7        tap          ttyp3        zero
fs1p0        pipe         sem          tap0         ttyp4
hd0          profiler     ser2         tap1         ttyp5
Notice the /dev/fs1p0 appears in the system but it is not mounted.  If I try to explicitly mount it:
# flashctl -p /dev/fs1p0 -m
flashctl: mounting partition failed
Because the simulated flash file system in RAM must always be erased before it is mounted when using flashctl.
Pass -i 1 to the driver when you start it.
Sent: Wednesday, May 29, 2013 5:00 PM
Subject: Re: devf-ram does not automount as described
# devf-ram &
[1] 61463
[1] + Done devf-ram
# ls
# ls /dev
General
http://community.qnx.com/sf/go/post101848
Attachment: HTML sf-attachment-mime13290 3.27 KB
Still not showing up.
# cat /dos/bp_fs.img > /dev/shmem/fs1
# devf-ram -i 1 &
[1] 57367
[1] + Done                 devf-ram -i 1
# ls
Maybe I'm doing something wrong with my efs filesytem build.  Here is my Makefile
all : my_efs_img
	echo "Making QNX6 file image"
my_efs_img : build
	mkefs -v build my_efs_img
clean :
	echo "Cleaning QNX 6 file system image"
	rm -f my_efs_img
And here is my build file:
[search=C:\QNX650\target\qnx6\armle-v7\bin;C:\QNX650\target\qnx6\armle-v7\sbin;C:\QNX650\target\qnx6\armle-v7\usr\bin;C:
\QNX650\target\qnx6\armle-v7\usr\sbin;C:\QNX650\target\qnx6\armle-v7\usr\photon\bin;C:\QNX650\target\qnx6\armle-v7\usr\
libexec;C:\QNX650\target\qnx6\armle-v7\lib\dll;C:\QNX650\target\qnx6\armle-v7\usr\photon\dll;C:\QNX650\target\qnx6\armle
-v7\lib;C:\QNX650\target\qnx6\armle-v7\usr\lib;C:\QNX650\target\qnx6\armle-v7\usr\photon\lib;C:\QNX650\target\qnx6\armle
-v7\etc;C:\QNX650\target\qnx6\etc;C:\QNX650\target\qnx6\usr\photon;C:\QNX650\target\qnx6\usr\photon\keyboard;C:\QNX650\
target\qnx6\usr\lib;C:\QNX650\target\qnx6\usr\share;C:\QNX650\target\qnx6\armle-v7\boot\sys;C:\QNX650\target\qnx6\usr\
lib\terminfo;C:\QNX650\target\qnx6\usr\lib\terminfo\a;C:\QNX650\target\qnx6\usr\lib\terminfo\q;C:\QNX650\target\qnx6\usr
\lib\terminfo\t;C:\QNX650\target\qnx6\usr\lib\terminfo\v;C:\QNX650\target\qnx6\usr\lib\terminfo\x;C:\QNX650\target\qnx6\
etc\system\config;C:\QNX650\target\qnx6\etc\ssh]
[block_size=128k spare_blocks=1 min_size=384k]
dummy.dat = {
This is a dummy data file.
Specify the sector size with -s0,1m,128k
Sent: Wednesday, May 29, 2013 5:24 PM
# devf-ram -i 1 &
[1] 57367
# ls
all : my_efs_img
my_efs_img : build
clean :
rm -f my_efs_img
dummy.dat = {
General
http://community.qnx.com/sf/go/post101850
Attachment: HTML sf-attachment-mime13294 4.03 KB
I think you meant -s0,1m,,,128k
The third argument for this option is aoffset (array offset info flash), the fourth is asize (size of flash array equal
to wsize), and the fifth is usize (physical erase sector size).  Works great!  Thanks for the help!
# devf-ram -i1 -s0,1m,,,128k &
[1] 40983
[1] + Done                 devf-ram -i1 -s0,1m,,,128k
# ls
bin      dos      fs1p0    sbin     usr
dev      etc      proc     tmp
# cd /fs1p0
# ls
dummy.dat
# cat dummy.dat
