Forum Topic - Help with mketfs buildfile: (2 Items)
Hi, I'm trying to run mketfs to create the filesystem with the following buildfile:
[virtual=x86,bios +compress] .bootstrap = {
    startup-bios
    PATH=/proc/boot:/bin procnto
[+script] .script = {
    devc-con -e -n5 &
    reopen /dev/con1
    devf-i365sl -r -b3 -m2 -u2 -t4 &
    waitfor /fs0p0
    [+session] TERM=qansi PATH=/proc/boot:/bin esh &
[type=link] /tmp=/dev/shmem
[type=link] /bin=/fs0p0/bin
[type=link] /etc=/fs0p0/etc
libc.so
[type=link] /usr/lib/ldqnx.so.2=/proc/boot/libc.so
libsocket.so
[data=copy]
devf-i365sl
devc-con
esh
When I run the mketfs command I get an error with the [virtual] attribute. Is there a replace for this attribute? Is it
needed with mketfs?
Thanks in advance.
I'm running QNX 6.4.1
Re: Help with mketfs buildfile
You seem to be using a OS Image Filesystem (IFS) build file with the mketfs utility which creates an Embedded
Transaction FileSystem (ETFS).  They are not the same things and the difference and usage is documented, please have a
look:
http://www.qnx.com/developers/docs/6.5.0_sp1/topic/com.qnx.doc.neutrino_building/building_nto.html?cp=13_2_3
http://www.qnx.com/developers/docs/6.5.0_sp1/topic/com.qnx.doc.neutrino_utilities/m/mkifs.html?cp=13_13_15_18
http://www.qnx.com/developers/docs/6.5.0_sp1/topic/com.qnx.doc.neutrino_utilities/m/mketfs.html?cp=13_13_15_15
[virtual] and [+script] are not supported in an mketfs build file.
