Forum Topic - C API similar to waitfor: (9 Items)
need to wait till a path (or a device node) to exists or appear in C program.
Is there a C API equal to waitfor command?
best regards,
Chun
RE: C API similar to waitfor
waitfor uses stat()
Here is an example:
int waitfor( char *path, unsigned wait_msec, unsigned wait_period_msec )
	struct stat		sbuf;
	unsigned		total = 0, ret;
	do {
		delay( wait_period_msec );
		total += wait_period_msec;
	} while ( (ret = stat( path, &sbuf )) == -1 && total < wait_msec );
	if ( total >= wait_msec )
		errno = ETIMEDOUT;
	return ret;
Chris
Sent: April-18-12 2:39 AM
To: general-filesystems
Subject: C API similar to waitfor
best regards,
Chun
General
http://community.qnx.com/sf/go/post92596
Re: C API similar to waitfor
Actually it uses waitfor() - it's in libgen.h
On 12-04-18 10:05 AM, Chris Travis wrote:
> waitfor uses stat()
> Here is an example:
> 	struct stat		sbuf;
> 	do {
> 	} while ( (ret = stat( path,&sbuf )) == -1&&  total<  wait_msec );
> 	if ( total>= wait_msec )
> 		errno = ETIMEDOUT;
> 	return ret;
> Chris
> From: Chun He [mailto:community-noreply@qnx.com]
> best regards,
> Chun
> http://community.qnx.com/sf/go/post92605
cburgess@qnx.com
Sure, but according to our documentation and the "actual?" lib/c/qnx/waitfor.c  it uses stat()  :-)
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.neutrino_utilities/w/waitfor.html
plus aside from the definition in libgen.c, waitfor() is not documented. :-(
From: Colin Burgess [mailto:community-noreply@qnx.com]
Sent: April-18-12 10:11 AM
Subject: Re: C API similar to waitfor
> waitfor uses stat()
> Here is an example:
> 	struct stat		sbuf;
> 	do {
> 		errno = ETIMEDOUT;
> 	return ret;
> Chris
> best regards,
> Chun
cburgess@qnx.com
General
http://community.qnx.com/sf/go/post92606
waitfor() should be used so that when / if it's
changed to not poll in a loop, everyone will
benefit.
> > waitfor uses stat()
> > Here is an example:
> > 	struct stat		sbuf;
> > 	do {
> > 		errno = ETIMEDOUT;
> > 	return ret;
> > Chris
> > best regards,
> > Chun
> > General
> > General
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post92607
If waitfor() doesn't use poll, it is preferred.
Which library includes waitfor()?
Thanks for quick responses.
-Chun
PR 77631 is a laundry list of undocumented functions. You'll be happy to learn that waitfor() is on the list.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
From: Chris Travis [mailto:community-noreply@qnx.com]
Sent: Wednesday, April 18, 2012 10:24 AM
Subject: RE: C API similar to waitfor
Sure, but according to our documentation and the "actual?" lib/c/qnx/waitfor.c  it uses stat()  :-) http://www.qnx.com/
Re: RE: C API similar to waitfor
Is this a document that is available on this website ? Can you link to it ?
RE: RE: C API similar to waitfor
No, I haven't written anything about waitfor() yet.
Technical Editor
From: Rohit Nair [mailto:community-noreply@qnx.com]
Sent: Wednesday, April 18, 2012 2:02 PM
Subject: Re: RE: C API similar to waitfor
General
http://community.qnx.com/sf/go/post92619
