Really strange problem with qnx6 fs
04/27/2011 3:55 PM
post85276
We're using a Transcend Compact Flash, model TS2GCF266, which is 2G, 266X SLC. The device does support the FLUSH CACHE
command, and it works fine with sync=mandatory.
However, if I create a qnx6 fs on the device and then write several megabytes worth of files, it gets a low-level error
and the device seems to go into some sort of write-protect mode where we have to cycle the power to clear it.
What's odd is that we can do the exact same thing with qnx4 fs, and we can write every sector on the device with dd. In
fact, I created a qnx6fs on another similar CF, and dd'ed the entire image to the "bad" flash without any problem. The
resulting CF boots up just fine, but any attempt to write a large file to it produces errors in the slog and the device
stops allowing writes.
I've tried everything I can think of, including sync=none, turning off DMA, etc., and it makes no difference. "
Something" that qnx6 fs is doing is causing this flash device to give an error.
I've reproduced in in various different machines, with two different CF modules, HOWEVER, it doesn't happen with every
module. I have a third CF of the exact same make & model, and it does not exhibit the problem.
I loaded "devb-eide eide verbose=5,master=verbose=5 cam verbose=5" and have the slog output of the resulting error, if
anyone wants to look at it. It doesn't seem to have a lot of info, other than that it was doing a write of 64K bytes
and then the next thing is a "reset completed after ~300ms".
If it was just a single device, I would dismiss it as bad, but two different ones?
lew
Re: Really strange problem with qnx6 fs
04/27/2011 5:15 PM
post85278
We had similar issue with Transcend IDE flash drive (4G). Our solution was to give up on this brand all together. Not
that there bad but Transcend and QNX don't seem to be compatible for some reason.
At the time I didn't feel like paying big money to have this issue fix (custom engineering). Plus from experience,
through foundry, the feedback from QNX is on the low side.
> The device does support the FLUSH CACHE command, and it works fine with sync
> =mandatory.
> worth of files, it gets a low-level error and the device seems to go into some
> write every sector on the device with dd. In fact, I created a qnx6fs on
> problem. The resulting CF boots up just fine, but any attempt to write a
> large file to it produces errors in the slog and the device stops allowing
> writes.
> etc., and it makes no difference. "Something" that qnx6 fs is doing is
> modules, HOWEVER, it doesn't happen with every module. I have a third CF of
> the slog output of the resulting error, if anyone wants to look at it. It
> 64K bytes and then the next thing is a "reset completed after ~300ms".
> ones?
> Thanks,
> lew
04/27/2011 5:50 PM
post85279
> give up on this brand all together. Not that there bad but Transcend and QNX
> engineering). Plus from experience, through foundry, the feedback from QNX
> is on the low side.
I hear ya. We've been using Transcend for many years because, in our experience, their quality has been good, and they
were the first out with really high-performance CF that supported DMA.
That said, I would think that QNX would be interested in knowing why a standard, off the shelf CFA and ATA compliant
device is not working properly. As you say, there appears to be some compatibility problem.
Unfortunately, we have a large number of these already deployed in the field so switching to another brand is not so
simple. We discovered the problem while testing a field upgrade image that reformats the filesystem as qnx6, but in
this case, the box had to be returned to us after the flash died during that process. Yuck.
lew
04/28/2011 7:56 PM
post85310
Update..... we took the slog info showing all of the commands that were issued to the drive and wrote a little program
to reply them, and it reproduces the problem, completely independent from the qnx6 fs. So it has nothing to do with the
filesystem, but simple the pattern of writes that was done to the flash.
We then ported the test program to Linux and the problem occurs equally well.
So bottom line, QNX is not at fault and we will pursue this with Transcend.
Thank,
lew
04/29/2011 5:04 AM
post85313
would you be willing to share your test program? We have had issues with Transcend and it's stability lately too.
Regards, PKY
> to the drive and wrote a little program to reply them, and it reproduces the
> with the filesystem, but simple the pattern of writes that was done to the
> flash.
> Thank,
> lew
04/29/2011 8:15 AM
post85315
> Hello,
> Regards, PKY
Sure, no problem, here it is.
On QNX, it was originally simpler with readblock() and writeblock(), but those functions didn't exist on Linux so we
changed to using lseek() instead.
Compile it with:
cc -O3 -Wall cftest -ocftest
Run it like this:
./cftest /dev/hd0 (or whichever device you want to test)
It's non-destructive because it reads every block before writing it back.
So..... what problems have you been having with Transcend?
lew
04/29/2011 9:41 AM
post85316
We have used Advantech Single Board Computers (SBCs) with Transcend 512MB industrial CFs.
Those CFs started to be slow, develop bad blocks and some CFs froze after several days, they were undetectable in BIOS
nor in card reader.
But it happened only in specific type of SBC (probably different chipset and timing of ATA communication). We have been
unable to find the reason, so we switched to other brand of CF for a given type of SBC.
We stress tested these CFs in other SBC and they worked fine. Definitely not the problem of writing too much to the CF.
PKY
04/29/2011 9:47 AM
post85317
Well, if it helps any, I wrote a little q&d program to erase the CF, hoping it might fix the problem. It didn't have
any effect, so I never turned it into a "nice" program, but you may find it helpful.
This program just blindly sends erase commands until it gets an error. Your MUST NOT have devb-eide running at the same
time as this program because it just writes the controller registers without any regard for other software trying to
use the device.
lew
