performance issue about dos filesystem on sd card
01/13/2011 12:58 AM
post82078
I tested the file r/w performance on sd card using imx53 bsp, and the result is 0.8Mb/s(write) and 10Mb/s(read). The
writting data rate is much lower than the result on eCos(A RTOS) while reading rate is a lilltle bit higher. Can anybody
explain that? Or any suggestion to impove the writting performance.
