Forum Topic - Preselecting and starting the correct partition/drive on the primary boot loader: (6 Items)
I'm having a problem setting up QNX to automatically boot without a keyboard or operator intervention.
I currently have an x86 system setup for data acquisition and need the system to startup complete and run the software
setup rc.local.
BUT....
The system hang on the primary boot loader with the following msg:
Press F1-F4 to select drive or select partition 1,2 1
If I have a keyboard attached and press enter, everything works perfectly but the system is meant to operate in the
field without intervention so how do I set this up to simply go ahead and select the default and continue without the
keyboard attached (I;m willing to put on a keyboard (although this seems ridiculous) but the system still seems to wait
when first powered up.
Stumped
James Kelley
RE: Preselecting and starting the correct partition/drive on the primary boot loader
> -----Message d'origine-----
> De : James Kelley [mailto:community-noreply@qnx.com]
> Envoyé : 30 septembre 2010 11:18
> À : general-filesystems
> Objet : Preselecting and starting the correct partition/drive on the primary
> boot loader
> system to startup complete and run the software setup rc.local.
> BUT....
Remove de .diskboot file on the second disk/partition
> but the system is meant to operate in the field without intervention so how
> without the keyboard attached (I;m willing to put on a keyboard (although
> this seems ridiculous) but the system still seems to wait when first powered
> up.
> Stumped
> James Kelley
> http://community.qnx.com/sf/go/post69183
Re: RE: Preselecting and starting the correct partition/drive on the primary boot loader
Where do I find this .diskboot file -- in which sub-directory -- I cannot locate it anywhere.
Did you perhaps mean .diskroot rather then .diskboot ???
I've very sorry to be so obtuse but I have very little experience with filesystems
Thanks in Advanced
James Kelley
Further Information
If I run the df command, I get the following:
/dev/hd0t179             8160920   5259310   2901610      65%  /
/dev/hd0t177            23085184    788762  22296422       4%  /fs/hd0-qnx6-2/
/dev/hd0                31277056  31277056         0     100%
I am assuming /dev/hd0t177 is the second partition
but if I run
ls -la on /fs/hd0-qnx6-2
I get the following
drwxrwxr-x  3 root      root           1024 Sep 30 18:16 .
drwxrwxr-x  3 root      root           1024 Sep 30 18:16 ..
drwx------     2 root      root           1024 Sep 30 18:16 .boot
I can find no files or other sub-directories in .boot
Any other suggestions
> locate it anywhere.
> filesystems
> Thanks in Advanced
> James Kelley
Yes, it should be .diskroot. See the Controlling How Neutrino Starts chapter of the Neutrino User's Guide:
http://www.qnx.com/developers/docs/6.5.0/topic/com.qnx.doc.neutrino_user_guide/starting.html
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
After re-reading your original question, I don't think an extra .diskroot file is your problem (it isn't used until
later). As I understand it, the primary boot loader should time-out and boot the default partition. What's the second
partition for?
