Re: 2 x Spansion S29GL01GR 1Gbit devf-generic issues
06/30/2010 2:37 PM
post58239
They reported receiving just the one polling error during the dd write
- I don't know at which point of the dd it happened.
On 06/30/10 14:33, David Sarrazin wrote:
> devf-generic is reporting that is sees two physical chips, spanning
> 0x800 128k sectors, and that the chips have a 16-bit data bus, and are
> all wired to the same 16 data lines.
> Did the pattern test work?
> David
>> -----Original Message-----
>> From: Gervais Mulongoy [mailto:community-noreply@qnx.com]
>> Sent: June 30, 2010 2:29 PM
>> To: general-filesystems
>> Subject: 2 x Spansion S29GL01GR 1Gbit devf-generic issues
>> Hello all:
>> Customer case where they have two 1G storage units sitting
>> behind a custom FPGA which makes them appear to the system as
>> a single 2GB device. (src:
>> http://theloop.ott.qnx.com/departments/its/salesforce/sflookup
>> /index.php?searchfield=casenumber&id=00102881&lookup=+Lookup+C
>> ase+#case-description)
>> The customer reported seeing the following issues:
>> - an increase in CPU usage during a writes to flash - this
>> happens when the partition spans both 1Gb storage units
>> - erratic behavior when device was 40-60% full
>> - amd_poll: 163 program error
>> (devf t3::f3s_aCFI_v2write:233) over poll waiting for write completion
>> I have advised them that the polling error is displayed when
>> a 1-bit error status is toggled. Since it is only a single
>> bit there isn't enough information to determine what the
>> error is, so further testing is required (we will ignore this
>> one for now).
>> I spoke with DaveS who suggested that they should create the
>> largest partition possible (at least spanning both storage
>> units) and write a pattern across the whole partition using
>> the dd utility. I have also asked them to restart the driver
>> with increased verbosity so we can verify that the driver is
>> "seeing" the 2GB device correctly.
>> I don't know enough about devf-generic to analyze the verbose
>> results so I could use a hand to confirm the logs indicate
>> that they are using a 2GB device and that any errors can be
>> accounted for. I also attach the one polling error they
>> received during the pattern write (no indication where the
>> writing was happening so I can't say if it was near or at the
>> boundary between storage units - which should be invisible to
>> the system afaik).
>> Thanks,
>> Gervais
>> General
>> http://community.qnx.com/sf/go/post58236
> http://community.qnx.com/sf/go/post58237
