Forum Topic - FFS3 behaviour in case of power loss while writing: (2 Items)
Hello all,
we would like to know how FFS3 in NOR flash devices behaves in case of power disruption while a write is in progress.
1) How likely is damage to the file being written to?
2) How likely is damage to other files in the same directory?
3) Is there a chance of corrupting other areas of the flash device, possibly if they reside in different partitions?
Are there any comparisons between FFS3 and QNX4 filesystem with regard to this? I am asking because QNX4 filesystem is
widely used and both QSS and customers have over time deveoped broad experience in what can go wrong and how to detect
and overcome it. Maybe some of this knowledge is also applicable to FFS3.
Does it make sense to try and place an ETFS into a NOR flash part?
Thank you.
-Albrecht
Re: FFS3 behaviour in case of power loss while writing
Is there an answer to this?
I've encountered an event where a folder (where files get written randomly to) completely disappeared from the folder
tree.  The only thing I can see is that a flash file write access was interrupted by a power outage and screwed up the
inodes or equivalent.  Sucks that chkfsys is not available on FFS3.
