02/19/2010 9:20 AM
post47755
Gary,
Thank you for this report. You are right that etfsctl requires an input stream capable of seeking, if there is a chance
of bad blocks on the output device. I will open a problem report to track/fix this.
Until then, the workaround is to use an input file capable of seeking.
David
> I've found a problem with etfsctl and stdin; specifically when runing etfsctl
> where the input file is stdin, and the output part has bad blocks.
> In trans_write(), if there was a problem writing the record to the part, there
> is some code to correctly reposition the input and output to allow the
> containing block to be skipped. However, if the input is stdin, and is coming
> from a pipe, the fseek() call to rewind the src will silently fail, and the
> resulting filesystem will be incorrect.
> For example, if one were to do something like:
> gzip -d /tmp/myetfs.gz | etfsctl -S -e -w - -c
> -garyf
