Forum Topic - cannot create file larger than 2GB on qnx6fs: (5 Items)
i'm trying to zip a hdd image to a file using the following command:
dd if=/dev/hd2 bs=2048k | gzip > /tmp/hdd_img.gz
when the filesize of the image file reaches 2,147,483,647 ( which is apparently 2GB ), i get the error:
gzip: stdout: File too large
i'm using qnx 6.4.1 with qnx6fs, which i thought doesn't have the 2GB filesize limitation.
am i wrong ?
Re: cannot create file larger than 2GB on qnx6fs
> am i wrong ?
fs-qnx6 does support >2GB files, provided the client app is suitably
built with largefile support (O_LARGEFILE, _FILE_OFFSET_BITS=64, etc).
Otherwise it'll get EOVERFLOW (hmm, which is "Value too large to be
stored in datatype", whereas "File too large" is actually EFBIG).
Check that all the utilities involved are largefile (they will link
against the open64() instead of open()); they appear to be to me:
   $ nm -D /bin/sh | grep open
            U fopen64
            U open64
            U opendir
   $ nm -D /bin/gzip | grep open
            U open64
            U opendir
   $ nm -D /bin/dd | grep open
            U open64
Check that /tmp is indeed a fs-qnx6 filesystem:
   $ df -n /tmp
   Filesystem           Mounted on        Type
   /dev/hd0t177         /                 qnx6
The only place fs-qnx6 raises EFBIG is if 3 levels of indirect blocks
are exceeded.  This imposes a limit of 256GB for a single file if
formatted at 1k blocks.  If you used "mkqnx6fs -b512" then that limit
would be much lower, 16GB, but is still >2GB observed.
So the best guess is that you are not writing to a fs-qnx6.  The
"df -n /tmp" bit would show that ... (are you sure you don't have
/dev/shmem mounted at /tmp, for example?)
thank you for your answers.
i've now done the tests and here's the result:
# nm -D /bin/sh | grep open
         U fopen
         U open
         U opendir
# nm -D /bin/gzip | grep open
         U open64
         U opendir
# nm -D /bin/dd | grep open
         U open64
# df -n /tmp
/dev/hd0t179         /                 qnx6
I fixed the shell but I'm not sure that's the
issue here.
RE: cannot create file larger than 2GB on qnx6fs
The filesystem doesn't have that limitation but most programs do.
> From: - - [mailto:community-noreply@qnx.com]
> Sent: Thursday, November 05, 2009 11:58 AM
> To: general-filesystems
> Subject: cannot create file larger than 2GB on qnx6fs
> am i wrong ?
> http://community.qnx.com/sf/go/post41433
