Forum Topic - gcov merge capability with mipsgcov_2.95.3 version: (5 Items)
Hi
I am having a situation where in
for the same executable I am running two test cases after one reboot in between and hence i would get two *.da files
with different lines of execution
but wanted to run gcov on consolidated or merged *.da files.
is there utility or any options to merge OR to carry out this operation?
thanks
Nagaraj
Re: gcov merge capability with mipsgcov_2.95.3 version
Nagaraj naik wrote:
> Hi
There is no utility to merge two separate .da files. If you invoke your
program several times it will try to write to the existing .da file and
if the arcs match it will aggregate the data; otherwise it will
overwrite the file.
Ryan Mansfield
>overwrite the file.
I am not quite clear on "if the arcs match" can you please elaborate on this?
thanks.
>> overwrite the file.
-fprofile-arcs instruments the possible arcs (branches) from one basic
block to another. If these arcs have changed the counts cannot be
accumulated. The data will not line up and the program flow will not
make sense.
Ryan Mansfield
we have not changed the arcs in this case even though the *.da files are getting overwritten, its not accumalating.
i.e. we are using the same executeble which is compiled with compiler version - 2.95.3, for serveral test cases
execuation,
Everytime we keep previously collected *.da files in place. but the new execution is completely overwriting the *.da
files losing old test case data.
can we know what shall be done on this?
I would say this accumalating *.da files for different execution is basic feature.
please assit here!
