RE: malloc causes segfault/SIGSEGV
08/24/2009 12:16 PM
post36541
This is a bug in the C++ library, I was told it wasn`t going to be fixed, your only option is to upgrade to 6.
> From: Rodrigo Campos [mailto:community-noreply@qnx.com]
> Sent: Monday, August 24, 2009 12:15 PM
> To: ostech-core_os
> Subject: malloc causes segfault/SIGSEGV
> I'm using C++ in QNX 6.3.2 and I got a segmentation fault while I was
> calling "put" on a ostream. The ostream, internally called malloc and
> it cause the segfault.
> Here is the backtrace from the core file:
> (gdb) bt
> #0 0xb031ee55 in _block_mem_malloc_align () from
> /usr/qnx632/target/qnx6/x86/lib/libc.so.2
> #1 0xb031ef6d in _band_get_aligned () from
> #2 0xb031f01b in _band_get () from
> #3 0xb03210ec in __malloc_lock () from
> #4 0xb03211c8 in __malloc () from
> #5 0xb031ea72 in malloc () from
> #6 0xb851abef in __builtin_new () from
> /usr/qnx632/target/qnx6/x86/lib/libcpp.so.3
> #7 0xb851a9f3 in __builtin_vec_new () from
> #8 0x080556a3 in stringbuf::overflow (this=0x7e5bf04, c=0) at
> /opt/qnx632/target/qnx6/usr/include/g++-3/sstream:110
> #9 0xb823951d in __overflow () at
> ../../../../libstdc++/std/std_valarray.h:268
> #10 0xb823dbdc in _IO_putc () at
> #11 0xb8253d30 in ostream::put (this=0x7e5bf00, c=0) at
> ../../../../libio/streambuf.h:395
> #12 0x0806a8a3 in operator<< (os=@0x7e5bf00, tag=@0x809f570) at rftag-
> analog.cc:44
> #13 0x080636e9 in operator<< (os=@0x7e5bf00, grp=@0x80c79b8) at
> ielgroup.cc:321
> #14 0x0806e0b9 in IElcomConnection::handlePeriodicGroup
> (this=0x80be0a0) at ielcomconnection.cc:558
> #15 0x0806de6a in IElcomConnection::thread_handlePeriodicGroup
> (arg=0x80be0a0) at ielcomconnection.cc:524
> Until #12 is what my program does, after that all is inside the call to
> "put" of the ostream (os is a ostream).
> From the back trace it seems clear that what is causing the segfault is
> inside the malloc, so it should be a bug in QNX's libc, if I'm not
> missing something.
> Just in case it matters, besides Apache, php, ssh and RealFlex (with
> Ls900 driver) its a plain/default QNX 6.3.2 run-time installation on
> x86. And this program (the one I pasted the back trace) is multi-
> thread, and this is the thread it causes the segfault.
> Also, I don't know how to reproduce it, it happened only once in almost
> 8 months.
> Does this happen to anyone (segfault in malloc) ? It's a known bug or
> can I report it somewhere else ? Does anyone know if 6.3 is maintained
> yet and I can expect a new release fixing this ?
> Thanks a lot,
> Rodrigo
> http://community.qnx.com/sf/go/post36539
08/24/2009 12:17 PM
post36542
See your other post in the other forum
> To: ostech-core_os
> (gdb) bt
> analog.cc:44
> ielgroup.cc:321
> missing something.
> 8 months.
> Thanks a lot,
> Rodrigo
