Forum Topic - More shell challenge: (4 Items)
OUTPUT="PROF=/dev/shmem/qprof"
$OUTPUT pterm program
This doesn't work as the shell will try to launch $OUTPUT which obviously doesnt work. I want it to just like if it
would be:
PROF=/dev/shmem/qprof pterm <program>
Any idea how to achieve this.  Can't use extern.  The goal is for <program> to have PROF set accordingly.  I understand
pterm would also get the variable but that's a non issue.
If pterm could support pterm PROF=... <program> that would have solved my problem ;-)
Re: More shell challenge
would be:
understand pterm would also get the variable but that's a non issue.
Can you use the 'env' utility?
RE: More shell challenge
> From: Sean Boudreau [mailto:community-noreply@qnx.com]
> Sent: Friday, August 21, 2009 6:35 PM
> To: ostech-core_os
> Subject: Re: More shell challenge
> obviously doesnt work. I want it to just like if it would be:
> <program> to have PROF set accordingly.  I understand pterm would also
I appears I sure can ;-)  Thanks Sean!  8 minutes for a response, after 5pm on a Friday.  You gotta love this place and
the people behind it!
> -seanb
> http://community.qnx.com/sf/go/post36464
On Fri, 2009-08-21 at 18:42 -0400, Mario Charest wrote:
> > To: ostech-core_os
Also, in situations where env is inappropriate, you can often use the
'eval' shell built-in, which is useful for running constructed commands.
