Forum Topic - Re: alloca: (6 Items)
Re: alloca
Any thoughts?
Aleksandar Ristovski wrote:
> Hello,
> Current definition of alloca creates problems in code like this:
>   char *str = strcpy (alloca (strlen (command_str) + 1), command_str);
> Compiler generates error:
>  error: null argument where non-null required (argument 1)
> Why did we define alloca the way we did?
> If there is no particular reason, then would something like this patch
> (attached) make sense?
> (Disclaimer: this is not patch submission, but rather an illustration -
> I don't know what would be the right way to specify always_inline
> attribute or inline modifier to make all supported compilers happy).
> Thanks,
> Aleksandar
RE: alloca
> From: Aleksandar Ristovski [mailto:community-noreply@qnx.com]
> Sent: July-06-09 3:10 PM
> To: ostech-core_os
> Subject: Re: alloca
> Any thoughts?
> > Hello,
> command_str);
Wouldn't it be the definition of strcpy?  Alloca could return NULL and strcpy will crash if the argument is null. Seems
to me like the error is deserved.  This code is broken, the return value of alloca should be checked,
> patch
> > Thanks,
> > Aleksandar
> http://community.qnx.com/sf/go/post33210
Re: alloca
Mario Charest wrote:
>> -----Original Message-----
>> To: ostech-core_os
>> Subject: Re: alloca
>> Any thoughts?
>>> Hello,
>> command_str);
Seems to me like the error is deserved.  This code is broken, the return value of alloca should be checked,
malloc can return NULL too, yet there will be no warnings here:
char *str = strcpy (malloc (strlen (command_str) + 1),
command_str);
gcc doesn't really know if a function can return NULL or
not, but it can 'see' if a value may get explicit NULL which
is happening in our alloca case:
#define alloca(s) \
((void*)(((__ALLOCA_ALIGN(s)+128)<__stackavail())?_alloca(s):NULL))
So my question is still:
>> patch
>>> Thanks,
>>> Aleksandar
>> OSTech
> http://community.qnx.com/sf/go/post33212
RE: alloca
> Sent: July 6, 2009 4:15 PM
> To: ostech-core_os
> Subject: Re: alloca
> >> To: ostech-core_os
> >> Subject: Re: alloca
> >> Any thoughts?
> >>> Hello,
> >> command_str);
> return NULL and
> > strcpy will crash if the argument is null. Seems to me like
> the error
> alloca should
> > be checked,
> char *str = strcpy (malloc (strlen (command_str) + 1), command_str);
> gcc doesn't really know if a function can return NULL or not,
> but it can 'see' if a value may get explicit NULL which is
> #define alloca(s) \
Since alloca() can determine ahead of time if the allocation will work
or not, it's better to define it so that the compiler will complain.
That way broken code can be fixed.
> >> patch
I never saw the patch proposal, it doesn't look like it was attached.
Re: alloca
>> To: ostech-core_os
>> Subject: Re: alloca
>>>> To: ostech-core_os
>>>> Subject: Re: alloca
>>>> Any thoughts?
>>>>> Hello,
>>>> command_str);
>> return NULL and
>> the error
>> alloca should
>>> be checked,
>> #define alloca(s) \
It is probably desirable to check for returned NULL, but it
is not required.
I would like to know if this was the intention.
>>>> patch
Interesting. My original post was not referenced when I
replied to myself:
http://community/sf/discussion/do/listPosts/projects.core_os/discussion.newcode.topc8327
(Note: that is not official patch proposal, it's an
illustration - I hacked it that way locally).
RE: alloca
Look at the caveats in the alloc documentation ;-)
> To: ostech-core_os
> Subject: Re: alloca
> Any thoughts?
> > Hello,
> command_str);
> patch
> > Thanks,
> > Aleksandar
