Forum Topic - How to remap system page RW:
Hi:
I'd like to be able to overwrite the system page entries in qtime (specifically modifying the nsec_inc entry). Someone
in a previous post mentioned using mmap_device_memory() to remap the area as RW. I'm not clear though on how to get the
physical address of the system page. Anyone have an example?
thanks
robert
Re: How to remap system page RW
mem_offset64 will give you the physically address of a virtual pointer.
Robert D'Attilio wrote:
> Hi:
> thanks
> robert
> http://community.qnx.com/sf/go/post31491
cburgess@qnx.com
RE: How to remap system page RW
Thanks Colin...moving forward now I get a "Permission denied" error from
mem_offset64(). Here is the code:
    struct qtime_entry* kernelQtime = SYSPAGE_ENTRY ( qtime );
    off64_t offset = 0;
    errno = EOK;
    if(mem_offset64(kernelQtime, NOFD, sizeof(qtime_entry), &offset, 0)
== -1)
        fprintf(stderr, "Failed to get phyaddr %s\n", strerror(errno));
        return;
    printf("Qtime physical addr 0x%x\n", offset);
    errno = EOK;
    struct qtime_entry* myQtime = (struct
qtime_entry*)mmap_device_memory(0, sizeof(qtime_entry), PROT_READ |
PROT_WRITE | PROT_NOCACHE, 0, offset);
    if (myQtime == MAP_FAILED)
        fprintf(stderr, "Failed to map qtime %s\n", strerror(errno));
        return;
    printf("MyQtime->nsec_inc: %lu\n", myQtime->nsec_inc);
From: Colin Burgess [mailto:community-noreply@qnx.com]
Sent: Thursday, June 11, 2009 1:20 PM
To: ostech-core_os
Subject: Re: How to remap system page RW
> Hi:
(specifically modifying the nsec_inc entry). Someone in a previous post
clear though on how to get the physical address of the system page.
> thanks
> robert
cburgess@qnx.com
OSTech
http://community.qnx.com/sf/go/post31524
I think you might need I/O privity for mem_offset64() on the syspage.
Try adding ThreadCtl(_NTO_TCTL_IO, 0).  (Note: I'm not positive about
that.)
>     off64_t offset = 0;
>     errno = EOK;
> == -1)
>         return;
>     errno = EOK;
>         return;
> To: ostech-core_os
> > Hi:
> > thanks
> > robert
> > OSTech
Tried that and it didn't work :(
Thanks anyways!
From: Neil Schellenberger [mailto:community-noreply@qnx.com]
Sent: Thursday, June 11, 2009 4:38 PM
To: ostech-core_os
Subject: RE: How to remap system page RW
that.)
from
>     off64_t offset = 0;
>     errno = EOK;
0)
> == -1)
strerror(errno));
>         return;
>     errno = EOK;
>         return;
> To: ostech-core_os
pointer.
> > Hi:
post
> > thanks
> > robert
> > OSTech
OSTech
http://community.qnx.com/sf/go/post31560
ok, well on the ppc a shortcut is to use the SYSPAGE_ENTRY(private)->kern_syspageptr value as a paddr, since the kernel
is mapped 1-1
From: Robert D'Attilio [mailto:community-noreply@qnx.com]
Sent: Thu 6/11/2009 5:07 PM
To: ostech-core_os
Thanks anyways!
To: ostech-core_os
that.)
from
>     off64_t offset = 0;
>     errno = EOK;
0)
> == -1)
strerror(errno));
>         return;
>     errno = EOK;
>         return;
> To: ostech-core_os
pointer.
> > Hi:
post
> > thanks
> > robert
> > OSTech
OSTech
OSTech
http://community.qnx.com/sf/go/post31570
Robert, what version of the kernel are you using again?
> Thanks anyways!
> To: ostech-core_os
> that.)
> from
>>     off64_t offset = 0;
>>     errno = EOK;
> 0)
>> == -1)
> strerror(errno));
>>         return;
>>     errno = EOK;
>>         return;
>> -----Original Message-----
>> To: ostech-core_os
> pointer.
>>> Hi:
> post
>>> thanks
>>> robert
>>> OSTech
cburgess@qnx.com
6.3.2
Sent: Monday, June 15, 2009 1:54 PM
To: ostech-core_os
> Thanks anyways!
> To: ostech-core_os
> that.)
> from
>>     off64_t offset = 0;
>>     errno = EOK;
> 0)
>> == -1)
> strerror(errno));
>>         return;
>>     errno = EOK;
>>         return;
>> To: ostech-core_os
> pointer.
>>> Hi:
> post
>>> thanks
>>> robert
>>> OSTech
cburgess@qnx.com
OSTech
http://community.qnx.com/sf/go/post31773
Re: RE: How to remap system page RW
Here's the code that we use, more or less (I've converted it from our C++ object model to C).  The difference is that we
 map the beginning of the system page, instead of trying to pick the qtime entry out of the middle, although in theory
that shouldn't matter.  This is tested on x86.
Note you have to be root for it to work - if you're not root you will get a permission denied error on attempting to map
 the system page.
#include <sys/neutrino.h>
#include <sys/mman.h>
#include <sys/syspage.h>
#include <errno.h>
#include <stdio.h>
#define PAGE_SIZE 4096
#define SYSPAGE_SIZE (2*PAGE_SIZE)
int main(int argc, char argv[])
    struct syspage_entry* rw_syspage = NULL;
    struct qtime_entry* qte = NULL;                           // Qtime entry in system page
    int i; off64_t p_addr;
    if ((i = mem_offset64((void*)_syspage_ptr, NOFD, 1, &p_addr, NULL)) != EOK)
         return -1;
    rw_syspage = (struct syspage_entry*) mmap_device_memory(NULL,SYSPAGE_SIZE,PROT_READ | PROT_WRITE,0,p_addr);
    if (rw_syspage == MAP_FAILED) {
        fprintf(stderr, "Failed to map system page %s\n", strerror(errno));
        return -2;
    // Load in critical structures.
    qte = (struct qtime_entry*)(((char*)rw_syspage) + rw_syspage->qtime.entry_off);
    printf("Success - new syspage vaddr: %X   new qte vaddr: %X\n",(unsigned long)rw_syspage,(unsigned long)qte);
    return 0;
RE: RE: How to remap system page RW
Thanks a bunch Will.
Unfortunately, mem_offset64() doesn't work on the PPC with the syspage -
I get a permission denied error (even running as root). Not sure if
that's a bug or a feature :)
The workaround (from Colin's post) is to use
    syspage_entry* pSysPage =
SYSPAGE_ENTRY(system_private)->kern_syspageptr;
since mapping is 1:1 on the PPC. Then I can pass that value to the call
to mmap_device_memory() and it works.
Cheers
robert
From: Will Miles [mailto:community-noreply@qnx.com]
Sent: Friday, June 12, 2009 11:31 AM
To: ostech-core_os
Subject: Re: RE: How to remap system page RW
C++ object model to C).  The difference is that we map the beginning of
middle, although in theory that shouldn't matter.  This is tested on
x86.
get a permission denied error on attempting to map the system page.
#include <errno.h>
#include <stdio.h>
!= EOK)
         return -1;
strerror(errno));
        return -2;
    return 0;
OSTech
http://community.qnx.com/sf/go/post31627
